Modding Vapochill LightSpeed
Discussion in 'Modding' started by ^Liam, 27 Nov 2004.
  1. ^Liam
    ^Liam What's a Dremel?
    7 Feb 2004
    Just a quick questiion really to anyone that has one. I want to add one to a Lian-Li PC70 unfortunatly the vapochill unit is 105mm shorter than the case. I was wondering how easy it would be to add the 105mm onto it, i have access to the a bender and 2mm galv steel so i can possibly make myself a new frame and transfer everything over to it but i'm not sure because i have never seen how the frame/chassis is bent, does anyone have pics or comments on this idea.
  2. adamjones01101
    adamjones01101 What's a Dremel?
    29 Jul 2004
    Think about making a whole new box out of aluminum for it...much easier solution than trying to extend the old one, and will probably look better, too. Plus, you can window and light it! :D
