Scratch Build – In Progress Vapor - laptop mod - finall photos
Discussion in 'Project Logs' started by awadon, 6 Mar 2013.
  1. awadon
    awadon New Member
    23 Jan 2010
    My Toshiby Satellite A200 needs a new case.
    Yesterday I've started glueing display matrix cover. Here you can see back side. It will be also laptop cover. You can see the brass inlay.
    There is a front frame.
    Today I've started to make some decorating elements.
    I've milled small groove to place them.
    A little sanding. A little milling and I can drill holes to join the two parts of the matrix case.
    End of day 2.
  2. Father-Time
    Father-Time New Member
    23 Feb 2004
    Me likey!
    tough job to take on i think, but judging by the start you are on it :)
  3. awadon
    awadon New Member
    23 Jan 2010
    I've added lcd hinges.
    And I was finishing cover a little more.
    End of day 3.
  4. awadon
    awadon New Member
    23 Jan 2010
    Yesterday I had no time to complete the worklog.
    I will probably put the keyboard in this way.
    A small fitting to lcd.
    And finished lcd cover
    End of day 4
  5. awadon
    awadon New Member
    23 Jan 2010
    Yesterday I've started to do some fittings of the motherboard.
    At the moment I've made a cpu fan grill:
    First panel with connectors: audio and SD card slot.
    And the last think for today is a Wi-Fi switch.
    End of day 6
  6. AverageNinja
    AverageNinja Almost an EpicNinja
    6 Aug 2012
    I'm really liking that!
    Subbed!
  7. C4B12
    C4B12 Minimalistic PC's
    6 Oct 2011
    Steampunk builds is always fun to watch and laptop-mods isnt easy to find. Looking good! :)
  8. Mechh69
    Mechh69 I think we can make that fit
    16 Sep 2009
    Great job so far I look forward to seeing more!
  9. awadon
    awadon New Member
    23 Jan 2010
    Thanks guys :)
    Today I've took care of the next part of the case.
    The second CPU fan grill and a second set of sockets.
    End of day 7
  10. woody_294
    woody_294 Wizard Ninja :P
    31 Dec 2008
    You sir, are a clock killer!
    Nice work
  11. awadon
    awadon New Member
    23 Jan 2010
    All elements on the first fitting.
    Here I have a plexiglass "embedded" in the wood. Underneath are LEDs.
    And the views from the sides.
    End of day 7.
  12. Cheapskate
    13 May 2007
    Really cool.:D I like how you inset the decoration. -Best use of a coat hanger EVER!
  13. awadon
    awadon New Member
    23 Jan 2010
    A few changes. But it's still all in the "raw state".
    End of day 9.
  14. kelmannen
    kelmannen New Member
    5 Feb 2011
    fantastic steampunk! :) really like the design tho i think you use more then needed thickness in the material :)
  15. awadon
    awadon New Member
    23 Jan 2010
    Thanks:) And you are right about thickness :) Wait a while, please.
  16. Waynio
    Waynio Relaxing
    20 Aug 2009
    Good to see you back with more awesome quality modding. :cooldude:
  17. awadon
    awadon New Member
    23 Jan 2010
    Hi and thanks Waynio :) I would like to make more of my projects. But it's a little hard to make them without sponsorship :(
  18. awadon
    awadon New Member
    23 Jan 2010
    They are just a few little things to do and the laptop cover will be finished.
    And here you can see the speaker covers.
    End of day 10.
  19. AlderonnX
    AlderonnX Member
    10 May 2012
    That is one awesome laptop sir!
  20. Allmighty Loki
    Allmighty Loki GP modder
    8 Nov 2009
    Great job!! I was thinking some time ago on doing something similar to that, but that level of attention to detail never went through my head!
