Modding Variable PSU
Discussion in 'Modding' started by woodshop, 25 Mar 2004.
  1. woodshop
    woodshop UnSeenly
    14 Oct 2003
    well i wasn't going to post this till it was done but seeing as how i was soldering till 2am in the morning the night before i left to go back to college and still did not get it all soldered and i can't solder here at college (stupid fire codes) i'm posting it now.
    this project had/has a purpose. i wanted something to power my breadboard so i could prototype another project. it was inspired by another project like this but it had a lcd meter on the varaible out. (mine whould have to if i hadn't borked it).
    ^^ PSU before Pics..^^
    ^^Material before Pics^^
    ^^Tool of Choice^^
    ^^ Tool of choice in a table.. sides getting slotted to let the PSU board fit^^
    ^^test fit^^
    ^^ Cutting the face plate^^
    ^^PSU gets a hair cut^^
    ^^Face Plate From left (outs) 5V out, 12Vout, and 0-12V out, From left (switches) power, 5V, 12V, Varable, Pot^^
    ^^ finshed not counting remaining wireing^^
    ^^ All Important Night Shot^^
    ^^Night shot in the day time^^
    yea the wireing i did get done was enouf to get it to power on + some more.
  2. Xgamer
    Xgamer What's a Dremel?
    29 Oct 2003
    Very nicely done :rock:
  3. coorz
    coorz Miffed
    25 Apr 2003
    Nice little useful mod, good one :thumb:
  4. Manitowic999
    Manitowic999 What's a Dremel?
    17 Mar 2004
    Looks good.
    :D
  5. SJH
    SJH Minimodder
    24 Dec 2003
    Excellent idea, and you've made it really well. Good job!
    -Sam
  6. TMM
    TMM Modder
    12 Jan 2004
    wow that looks great dude, are you gonna give it a nice finish or leave it as bare wood :D
    :thumb:
  7. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    WOOD_IS_GOOD______________________
  8. Hippo
    Hippo Pre-dates 5.25" Floppies
    7 Mar 2003
    Not a bad job you've done there :) Shame things arnt a little more level/square but then Im a stickler for things being aligned.
    Quick note to modsquad, when quoting someone please only quote the useful bits. Seeing all the pics being reposted in the SAME thread makes it a little unreadable. Thanks :D
  9. DaSuperFly
    DaSuperFly What's a Dremel?
    19 Apr 2002
    You've done a really good job of it :thumb:
    I'm hoping to make an external PSU for powering some cathodes and this is pretty inspirational!
  10. SJH
    SJH Minimodder
    24 Dec 2003
    Would you mind editing your post so you don't quote all the pictures again? It clutters things up a little ;)
    -Sam
  11. instant rice
    instant rice What's a Dremel?
    20 Jan 2004
    I want one! That looks great, woodshop.
  12. woodshop
    woodshop UnSeenly
    14 Oct 2003
    no i do plan on pluging the holes and staining and varnishing it.. once i get the wiring done that is. that way i won't kill the finish eather by accident with the soldering iron or by scraching it..
    modsquad!!!!!!!!!!!!!!!!!!!! ditch the pics!!!!!!!..:naughty:
    whay to you mean level?? what do tou mean square?? the box is square (all angles are 90 degree) but the box is soposed to be a rect. and level is a debatable subject :D :naughty: :naughty:
  13. woodshop
    woodshop UnSeenly
    14 Oct 2003
    so bulid one...
    it consists of one $10 cheep but psu some cheep smoked plekie 2x cheep blue led fans about $8 in pine and mis ele crud..
  14. MrDT
    MrDT fapfap
    14 Jun 2002
    Nice one, ive seen full project development setups built before now, but they all seem a bit too big. Nice compact and tbh the perfect size to just plop on a bench ready for you to start testing.
    A useful project nicely done :)
  15. Murdoc
    Murdoc Gas Mask..ZOMG
    25 Jul 2003
    I did a similar thing with a 550W generic PSU, it doesnt look no-where near as good as yous, i glued the PSU to a plank, and used copper pipe pushed through the plank to connect croc clips to, works great but yours is a much better design :thumb:
    'doc
  16. Hippo
    7 Mar 2003
    I meant the switches/switch legends on the front of the PSU, there not level with each other or the edges. Also the knob could have done with moving up and right a bit. It just makes it a little more pleasing to the eye IMHO. Maybe you should have used 80mm fan grills instead of 92mm ones. Good woodworking thou, wish I had the skill/tools to woodwork :thumb:
  17. woodshop
    woodshop UnSeenly
    14 Oct 2003
    ok no excused for the switches.
    the knob is where it is becouse i still may but the lcd volt display thing in the upper right hand corner.
    i ordered 80mm but the darn place sent 92mm. and sent 3 when i ordered 2.. o well what do you want for $.49 cent items..
  18. Hippo
    7 Mar 2003
    Ahh I understand the placement of the knob now. Have you tried opening up the holes for the switches a little ? Since you've got large bezels you could open up the holes and then try and get them in line a little better.
    Shame on the fan grill thou, I have used a 92mm grill before on a 80mm fan, all I did was rotate the grill about 22 degrees :confused:. I think thats right, so its like this -> + x <- if you get what I mean :)
  19. TekMonkey
    TekMonkey I enjoy cheese.
    6 Dec 2002
    Yes, and it also wastes his bandiwidth. Also, whats with you and underscores? :eyebrow:
    And woodshop--are they that smart that they know when your soldering inside? Why not just solder outside? Just pretend your having a smoke if they say anything :hehe:
  20. woodshop
    woodshop UnSeenly
    14 Oct 2003
    it's a good idea thats why i thought of it allready..
    it's not as easy as yout think though.. the screens in the windows are not removable.. and finding an outlet out side is impossable.. so unless i take the cover plat off of a lamp post and install an outlet. (which i don't think campous security would like to much) i don't think it'll happen... + there is still snow on the ground.
    i could solder in my car with an inverter but sitting in a parking lot half out of a car with a soldering gun wouldn't look to good to campous security eather.
