Electronics Variable resistors
Discussion in 'Modding' started by Silver Spoon, 5 Jul 2006.
  1. Silver Spoon
    Silver Spoon What's a Dremel?
    12 May 2006
    Would '100ohm linear variable resistors' be suitable for controlling fans. Sorry it is a very basic question but i've only just started with electrics.
  2. agent420
    agent420 What's a Dremel?
    18 Apr 2006
    Rheostats can work, but they must have the correct power rating. See this page.
    Other methods such as using a variable regulator, switched diodes or PWM can be more efficient at the expense of being a little more complex.
  3. bender386
    bender386 What's a Dremel?
    5 Jan 2006
    dont use a pot it will catch fire.
  4. agent420
    18 Apr 2006
    Yeah, my pot always catches fire :hip:
    Seriously, if the rheostat power rating is correct it won't burn up. But rheostats do work by converting the uneeded energy into heat, which is why the correct rating is so important. That's also why some of the other methods are preferable in many instances.
  5. Silver Spoon
    12 May 2006
    Agent420 said that they convert the energy that isn't needed into heat so could i just passively cool them with a couple of nb heatsinks i have lying around. Thanks for the quick replies.
    Just remembered, i have some guitar pots lying around, does anyone know if they would do the job?
  6. agent420
    18 Apr 2006
    I don't think heatsinks will help, it has more to do with the internal construction.
    If memory serves correctly, common guitar pots are roughly 1/2W. That may not be high enough to work safely. They are also typically several hundred K resistance, which will push the working area to a small section of the control arc.
  7. Silver Spoon
    12 May 2006
    I'll give it a go with an old psu fan i have and if that sets fire to my carpet i'll stop. Thanks for the info anyway.
  8. Elv13
    Elv13 What's a Dremel?
    26 Apr 2006
    this will not burn
