I need to know the code for VB where it centers on a certain area (in say Webrowser1.) to x,y coordinates. I had this in some old code on my harddrive but when it died I lost it. Also, i know how to use sendkeys ect. but how would I make it 'hit' enter after? Thanks.
What's the "it"? VB implies a windows application; so to hazard a guess 1. Move the components by setting its Top and Left properties. Remember to recalculate its width and height though in relation to the Form's size, otherwise the form will just be moved. 2. If you want to use SendKeys to 'hit' enter use the arguments "{ENTER}" or "~" for the .Send or .SendWait methods. Stu
Thats not exactly what I wanted, I need to say... have it move the scroll bars so that I can only see a certain part and then have it remove the scroll bars. Edit: Found it out, I cant beleive i forgot these commands. Code: Private Sub RuneWeb_DocumentComplete(ByVal pDisp As Object, URL As Variant) Dim wbrowse As Object Set wbrowse = RuneWeb.Document.Parentwindow wbrowse.Scroll 45, 117 Set wbrowse = RuneWeb.Document.body wbrowse.setAttribute "scroll", "no" End Sub
