Other VB Help: Copy cells to sheet on cell criteria
Discussion in 'Software' started by jopers1986, 2 Feb 2010.
  1. jopers1986
    jopers1986 Minimodder
    7 Jan 2005
    Hi Guys,
    I've having some issues, found odds and ends of code that partially work, but can't get them to do just what i want.
    i have 2 main sheets, Data and Archive.
    Basically what i want to do is click a button that will copy all rows, from row 10 down, where the value in column P for that row is a value (<> "") to the archive sheet.
    Is this possible?
    Thanks for advance for any help!
    Rich
  2. jopers1986
    7 Jan 2005
    Any ideas please? i'm getting desperate!
    Thanks
  3. Landy_Ed
    Landy_Ed Combat Novice
    6 May 2009
    Have you tried recording a macro while performing the actions you want to achieve manually? Once you've got the base code generated, the rest can be added later.
