Development vb inputbox
Discussion in 'Software' started by ahug4122, 30 Nov 2004.
  1. ahug4122
    ahug4122 What's a Dremel?
    16 Sep 2004
    hey guys
    if i have a inputbox
    input1 = inputbox("pop")
    how do i use that value
    eg like if input1 = (something) then
    something else
    i keep on getting a error
  2. laoda
    laoda What's a Dremel?
    27 Nov 2004
    What error are you getting? Can you post your code as you have it written?
  3. ahug4122
    16 Sep 2004
    Code:
    Private Sub Form_Load()
    in1 = InputBox("how are you", "good or bad", , 500, 500)
        If in1 = "good" Then
            MsgBox "thats great"
        Else
            MsgBox "not so great"
        End If
    End Sub
    all i want is to be able to is read the value in in1 (inputbox1)
  4. ahug4122
    16 Sep 2004
    Code:
        Else
        End If
    End Sub
    plz tH4ñx
  5. djengiz
    djengiz Pointless.
    16 Aug 2002
    You got MSDN? It has a good example in it. type inputbox and use F1 for MSDN
  6. Hepath
    Hepath Minimodder
    20 Oct 2003
    OK,
    Assuming your using VB6 and a standard vanilla windows executable (you've pasted a Form_Load so I'm guessing it is) the only error that would produce is a syntax error stating in1 is undefined.
    add:
    Dim in1 as string
    as the first line after the function declaration and you should be fine. Its all down to the fact that option explicit will be declared (which you should really always have.)
  7. ahug4122
    16 Sep 2004
    thank you guys i can't belive it is as easy as a dim statment you guys rock i got 95% for my test now you rock
