VB.NET and C#
Discussion in 'Software' started by smithcarvo, 8 Sep 2008.
  1. smithcarvo
    smithcarvo What's a Dremel?
    13 Aug 2008
    Hi all,
    Can any one help me,what is the difference between VB.NET and C#?
    I will highly appreciate your feed back.
    Thanks in advance.
  2. RTT
    RTT #parp
    12 Mar 2001
    vb.net is visual basic implemented on the .net framework and c# is a language developed by microsoft
  3. BentAnat
    BentAnat Software Dev
    26 Jun 2008
    Dependant on where in the world you are, C# is more wanted than VB.NET.
    C# uses C-style syntax, and VB.NET uses VB style syntax (making C# easier to learn, IMO).
    So long as you're using the .NET framework (which is default, if you're running Visual Studio.NET), they both compile to the same code.
    C# is more popular (as said - that's conditional) due to easier readability, etc.
    Oh, and VB makes you lazy... :p
  4. Akava
    Akava Lurking...
    28 Jul 2007
    VB.net is a horrible language.
    I had to study it last year for college... it sucks.
  5. koola
    koola Minimodder
    11 Jul 2004
    csharp is a lot better.
    If you're developing software, stay clear of .Net as it's really easy to decompile/reverse engineer.
  6. Elv13
    Elv13 What's a Dremel?
    26 Apr 2006
    And work only on Windows. You should use C++ and wxWidget or Qt (if you want to make your code open source), they are good too and crossplatform. Qt is better than .net, but you have to pay a licence if you dont want to publish your code.
  7. Firehed
    15 Feb 2004
    To answer the question... the differences are mostly syntactical. I'm not particularly talented at either (due to lack of experience, which is due to a serious lack of caring), but C# as you might expect is relatively close to other C-style languages. VB is just... weird. I swear it's got the least logical syntax of anything out there, including the block of regex that is Perl.
    Though given your sig, it seems you should know that already.
  8. dark_avenger
    dark_avenger Minimodder
    9 Jul 2008
    C is a lower level programming laungauge and gives you more access to devices, etc.
    VB is less powerful.
  9. BentAnat
    26 Jun 2008
    That's C/C++ though...
    C# is based on .NET, as is VB.
    There ARE differences - things you can do in one of them, that the other can't do like that, but the majority of it .NET.
    They also compile to the identical LLC
