i want to fit a vcd/lcd into my rig but dont have any room left unless i cut a hole in the top ,anyone know if theres one available that would fit in the floppy slots,i've got 2 spare [one above the other] ill also have to take in consideration a nice surround.thanks in advance oh and while i remember anyone know the site addy for a guy called cheeseman ive lost his link,his site had all the lcd/vcd answers im looking for
how big is it? or if you havent actualy got one yet then make sure that you get the measurments from the site b 4 and verify that it will fit in the floppy bays good luck mate try MO web-site, i think that goo did this if i remember correctly, or it may have been in the 5'2 bays, have a search for his article.
AW3K put an MO LCD into two 3.5" bays: http://forums.bit-tech.net/showthread.php?s=&threadid=8060&highlight=LCD And I put my VFD into two 5.25" bays: http://www.bit-tech.net/article/89/ Shout if you need help - I'll answer any questions you have, and I'm sure AW3K will as well.
thanks,thats how i want mine [AW3K's] abeit in a different case,all i need to know now is what size that display is and i can go ahead and order it
I put a 4 line MO in the two 3.5" drive bay of my CM200. The board extends beyond the size of the bays by a few mm top and bottom, but this doesn't matter as it's behind the faceplate of the machine. Si.
