vector art/cnc machines
Discussion in 'Photography, Art & Design' started by Agent_M, 17 Feb 2008.
  1. Agent_M
    Agent_M Minimodder
    4 Feb 2005
    i was wondering if any of you knew of an effective vector based program that can be used with CNC machines, as we have some at uni that i want to take advantage of. the technician told me to use illustrator and save the files as .SVG but i cant get the hang of illustrator.
    also i have no experience with making images for cnc machines, and i was wondering if theres a way to set up depth for the cuts in a program, or would it have to be a separate image that the cnc machine is then told to do with less power(they have laser cnc machines).
    on tuesday i will ask them about it, but id like to get started on some designs before then ideally.
    any help is much appreciated.
  2. iddqd
    iddqd What's a Dremel?
    6 Feb 2006
    Tips for Illustrator; spend time in the help file and play with paths (lines) - if you can draw what you want with those lines, you're good.
  3. Cabe
    Cabe What's a Dremel?
    14 May 2002
    Another one is to use http://www.inkscape.org/ its somewhat easier to use than Illustrator (although not as powerful or polished) and produces SVG's
  4. Agent_M
    Agent_M Minimodder
    4 Feb 2005
    the problem i have with illustrator is, that i just want to do simple outlines, but it doesn't seem to do things like snap to the length of a parallel line like in programs like sketchup.
    ah it seems that sketchup can export as DWG :) should be able to use that then.
    i think the reason they said illustrator to me was because at the time i was thinking about including text. but for this work i dont need any text included so hopefully they will accept DWG files.
  5. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    I would also recommend inkscape. It seems to be way easier to use than illustrator. It do have some bugs, but it's bearable.
    The thing i hate about illustrator is that to bend a line you have to use those damn handles, while in inkscape you can just click on the line. makes things much easier.
  6. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    That's more of an industry-standard thing. After close to 18 years of graphic-design, it's second nature for me personally to use them. I can recall since version 88+, Illustrator has always been that way. Corel has the same or similar feature regarding the use of 'handles' as well. That's just how it's always been done! :)
  7. Smilodon
    25 Mar 2003
    Ah. i see.
    But just because it "have always been that way" doesn't mean that it's a good solution. ;)
  8. E.E.L. Ambiense
    26 Jul 2007
    It is in the hands of professionals! ;) But I see your point regardless.
  9. OleJ
    OleJ Me!
    1 Jul 2007
    Perhaps "Solid Works" ?
    All depends on the depth wise complexity of what you want to create I guess.
    I would reckon that if you bring your dwg with or without having your 2d extruded, they can help do that.
  10. ivanirons
    ivanirons What's a Dremel?
    17 Dec 2007
    CNC Art Conversion Videos
    Agent_M,
    I am just putting together a tutorial series on taking an image and converting it to CNC. I use Illustrator, so you may be able to pick up some tips. The series is 13 Videos Long and I just about have them all cooked.
    You have to be registered on the site to get to the videos, but signing up is free. Not much of a barrier.
    Here is the registration link:
    http://www.cncinformation.com/index.php?option=com_comprofiler&task=registers
    Have a good one,
    Ivan Irons
