Case Mod - In Progress "Venom" Modded NZXT Phantom (Build log) Feb. 4th 2012
Discussion in 'Project Logs' started by mybadomen, 5 Feb 2012.
  1. mybadomen
    mybadomen What's a Dremel?
    19 Jan 2012
    Hiya guys i am pretty new to this forum but have been on others for a couple years now.I will start by saying Hi to all the incredible Modders and builders on this site and hope i will have a ball here and fit right in.
    Ok so to start the build Log:
    The Victim:
    White Nzxt Phantom with Blue Led's
    Venom Build Specs:
    Intel i7-2700k
    AsRock Fatal1ty Professional Z68 Gen 3
    4 Gig's Corsair Dominator GT's 2133 C9 1.5v
    PowerColor 2 Gig HD6970
    2 OCZ 60 gig SSD's Vertex 3's Raid 0
    2Tb WD Black Edition 64mb Cache
    Cougar G1050 Power supply
    Asus Dual Layer Burner
    Antec Veris Multimedia Station Premium
    Cooling:
    Rasa Pump/Res Combo
    Rasa RS360 Radiator for Top
    Rasa CPU Block
    Magicool Extreme 240 Bottom Radiator
    Ek Nickel HD6970 reference Block
    EK Nickel Dominator Ram Block
    EK-MultiOption RES X2 - 250 Advanced Reservoir (8 Total Ports)
    10 Akasa Viper 120mm Fans 83.63 CFM
    1 Akasa Viper 140mm Fan 110.61 CFM
    10 feet Primochill Primoflex Pro Tubing (Black)
    8 Bitspower 1/2"ID X 3/4"OD Compression Fittings
    3 Bitspower 1/2"ID X 3/4"OD Rotary 45 degree Compression Fittings
    3 Bitspower 1/2"ID X 3/4"OD Rotary 90 degree Compression Fittings
    Silver coil and Biocide
    Yellow Anti Kink Coils
    Other Parts:
    100 feet Yellow Parachute Cord 550lb
    100 feet Black Parachute Cord 550lb
    2 white Cathodes
    2 Led strips
    2 Frozencpu Led Res Plugs.
    Handful of white Led's
    Plexi Glass
    C Channel Molding
    Black Vinyl meterial
    Pci-e Slot covers (Black)
    Rivets/Screws and other hardware.
    2 Quarts Automotive Primer
    2 Quarts Lacquer Automotive Chrome yellow Base Coat
    1 Quart Lacquer Automotive (Jet Black)
    2 Quarts Lacquer Automotive Gloss Clear coat
    2 Cans of Adhesion Promoter
    Some metal Stock
    (I think i got everything there in the list)
    Will add more shortly. Stay tuned.
  2. mybadomen
    19 Jan 2012
    Testing Equipment before voiding warranties:
  3. mybadomen
    19 Jan 2012
    Update:
    Finished build but will add the complete Log soon as i can: I was in a Mod of the Month contest on another forum which i Won but i was not allowed to post the build anywhere else while the contest was going on so now the log is way behind. And i am In the Middle of a new Sponsored NZXT Switch 810 build so as soon as i get the chance i will update the whole work log.Its going to be allot of work to move it so i need at least a whole day set aside to do it. Thanks for understanding and hope you like the build.
  4. mybadomen
    19 Jan 2012
