Modding Vertical mounted GPU + Cooler Master WCing kit in Fractal R5
Discussion in 'Modding' started by Guest-16, 7 Feb 2018.
  1. Guest-16
    Guest-16 Guest
    I am playing with ideas here. The hardware isn't high-end but I thought it would be interesting to do the vertical mount in an R5 with a GTX 960 mini, which to my knowledge no one else has done. I'll throw in a LiHeat PCIE extender between them. The mix of hard/soft tubing is because a lot of the Barrow hardline connectors and adapters I bought have gone 'bad' - visible rust in the gaps - and I wanted more flexibility to play rather than use up hard tubing. That Byskyi GPU block: $10USD!
    The CM watercooling kit - the pump/res combo is really nice and meaty, but the rest feels so-so. I will have to see if 350l/hr can actually push this loop or not. The idea is to splash it with some white LEDs later too, so the whole build will be roughly co-ordinated in black-white.
  2. The_Crapman
    The_Crapman Don't phone it's just for fun. Lover of bit-tech
    5 Dec 2011
    Nice. What connector you using for gpu to monitor? The vertical slot in my arc is fairly thin and I had to trim the plastic off a dvi to get it to fit. Using a display port now though.
  3. Guest-16
    Guest-16 Guest
    DP. I'm only losing a DVI which I don't use :)
  4. The_Crapman
    5 Dec 2011
    And with that small card and block you shouldn't get any droopage either.
  5. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    What riser are you using? I had big problems with mine (admittedly it was thermaltake, so I probably deserved it).
  6. Guest-16
    Guest-16 Guest
    LiHeat 250mm http://www.ebay.com/itm/122951533417
    Local company (father/son iirc) here who sponsor several modders and make quality, shielded cables.
  7. Ending Credits
    4 Jan 2008
    Do you recommend them? Might replace mine.
  8. Guest-16
    Guest-16 Guest
    I'll let you know in a ~week. The order just went through and they're posting it tomorrow
  9. Cheapskate
    13 May 2007
    I can recommend them. Mine works great. They test them before they ship too.
  10. The_Crapman
    5 Dec 2011
    Might have to pick one of them up to replace my dodgy foil covered one. What's wrong with the thermaltake one's?
  11. Guest-16
    Guest-16 Guest
    Highlighted the issue for you.
  12. Ending Credits
    4 Jan 2008
    Well the 30cm I bought doesn't even work with PCI-E 3.0 on my mobo. Had to force it to 2.0.
    Thermaltake gives you nice looking (well, some of their stuff) products for cheap, but ultimately you pay with your sanity.
  13. BU5H W00K1E
    BU5H W00K1E Minimodder
    18 Nov 2017
    I have my 1080ti with a waterblock vertical mounted it looks good
    Guest-16 likes this.
  14. CAF PCs
    CAF PCs Custom PCs
    11 Mar 2018
    I too have one of those eBay $50 risers. I talked with them before about what I was trying to do and they sent me photos of different possibilities and were extremely helpful. And of course yes it works great. Definitely recommend them even if they might be double the price of a perfectly capable (wider though) one from Amazon
  15. Guest-16
    Guest-16 Guest
    Nice display
  16. CAF PCs
    CAF PCs Custom PCs
    11 Mar 2018
    @BU5H W00K1E The Waterblock gets drowned out by the brightness on the top part of the build since there are no lights to match the bottom part
  17. BU5H W00K1E
    18 Nov 2017
    ya sadly where the psu cover is it blocks the lights. but imma be doing a rebuild of this system in the late summer
  18. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
  19. CAF PCs
    CAF PCs Custom PCs
    11 Mar 2018
    Li-Heat isn't as aesthetically pleasing IMO compared to say Thermaltake's. Theirs looks higher quality and finished where (at least the one I received) looks like more of a prototype. The black covering the cable wasn't perfectly uniform and has a slight wave to it so it doesn't lay completely flat
  20. NoobNeb
    NoobNeb Enthusiastic Lurker
    14 Nov 2011
    How you finding the byskyi block? Did you get it from aliexpress?
