Linux vertical refresh rate and horizontal sync
Discussion in 'Software' started by Onyx, 31 Aug 2006.
  1. Onyx
    Onyx What's a Dremel?
    13 Jun 2006
    hello, i need some standard vertical refresh rate and horizontal sync rates for a screen running at 1920x1200 @ 60Hz. my system is an Alienware Area51m 5750.
    thanks.
  2. Elv13
    Elv13 What's a Dremel?
    26 Apr 2006
    /etc/X11/xorg.conf
    depending of the driver you are using, chnage parameter in this file
  3. simon w
    simon w What's a Dremel?
    3 Nov 2003
    The OP is asking what their monitors frequencies are, not how to change them ;)
    In my experience, monitor frequencies vary from brand to brand. What monitor do you have? (Alienware's support section seems to require username/password)
  4. Glider
    Glider /dev/null
    2 Aug 2005
    Yeah, it depends on what monitor you use. It's probably listed in the spec. sheet that came with the monitor.
  5. JuMpErFLY
    JuMpErFLY Minimodder
    13 Mar 2003
    Code:
    gtf 1920 1200 60
      # 1920x1200 @ 60.00 Hz (GTF) hsync: 74.52 kHz; pclk: 193.16 MHz
      Modeline "1920x1200_60.00"  193.16  1920 2048 2256 2592  1200 1201 1204 1242  -HSync +Vsync
