Modding vertical window mods(nee dhelp
Discussion in 'Modding' started by spyder09, 3 Sep 2006.
  1. spyder09
    spyder09 What's a Dremel?
    31 Aug 2006
  2. Mr_SCSI
    Mr_SCSI What's a Dremel?
    13 Apr 2004
    This has been asked/discussed already iirc... do a search. :search:
    EDIT ~
    [helpful mode]
    here you go... Scissor door mod
    [/helpful mode] :thumb:
  3. spyder09
    31 Aug 2006
    I know but I have questions about it.
  4. Mr_SCSI
    13 Apr 2004
    Mmm... thought the questions you asked had been discussed in the link I put up?
  5. spyder09
    31 Aug 2006
    Well I wanted to know what hinges are they? And are there other places to get them.Cause the place in the link doesn't show there prices or anything.
  6. Mr_SCSI
    13 Apr 2004
    As mentioned in the link, friction hinges.
    All good DIY, Hardware places should have them.
    EXAMPLE 1
    EXAMPLE 2
    Although from the original project pics they appear to be the more basic style sliding/friction hinges you get in kitchens, from the over head cooker hood cupboards etc. Can also be called = 'Stays' or 'Braces'
  7. spyder09
    31 Aug 2006
    Oh thanks
  8. spyder09
    31 Aug 2006
    OK I have googled friction hinges and have pretty much came up with nothing.CAn you help?
  9. spyder09
    31 Aug 2006
  10. spyder09
    31 Aug 2006
    hello?
  11. Mr_SCSI
    13 Apr 2004
    Have look in the 'Projects Log' forum
    have a Look at the 'Super hornet' thread.
    Those friction hinges look almost identical to the ones in the original link you posted.
    had a quick read but didn't see any mention of the place of purchase, but ask the author and see what he says.
    :thumb:
  12. spyder09
    31 Aug 2006
    Ok I sent a pm to Susadu. He is the one that built the Super hornet.
    I am sorry if I am bugging you guys. But it is importnant that I find out where to get those hinges.
  13. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    Well I was the one who helped out the other guy that was looking for the exact same information. My first sugestion is tell us where exactly you are in the world. Then a quick google search will give you all yoru answers.
  14. spyder09
    31 Aug 2006
    I live in the States. And I have googled them. Susadu said he got them from Acehardware.
  15. spyder09
    31 Aug 2006
    See I am building a case from Alum Angle.
  16. spyder09
    31 Aug 2006
    Good News. I have been tlaking to Susadu, and we are going over some ideas for my pc case. I know its gonna be a,"Cobalt Blue Metallic, paint job. I thought about making a grim reeper theme. And put a fogger in it, so it will simulate a foggy night at the cemetery.
    Tell me what you think?
  17. greensabbath
    greensabbath Got Wood?
    19 Apr 2005
    i don't know if cobalt blue goes with a grim reaper theme since that guy kinda reminds me of the color black instead. Also i'd be careful of a fogger machine in a case because the vapor could short stuff our maybe, but hey, go for it if you want.
  18. spyder09
    31 Aug 2006
    The grim reeper was just an idea, but I am gonna go with cobalt blue.
  19. douphus
    douphus What's a Dremel?
    26 Aug 2004
    Hate to bring this thread up again but we actually never did answer the question of what hinge was used to produce the scissor-style panel doors. Friction hinges are what he used for the front panel on the tribal mod case but if you notice, the side panels go out a bit then up, rather then flap out like on the superhornet so it is probably a self-designed or modified hinge mechanism. As for googling, I've looked all over the net as well as email hinge manufacturers without any luck so far. If someone can get me a design of the automotive hinge we can miniaturize it!
    Oh and interesting worklog link by the same guy as the superhornet and tribal
    Update 03 - 04-24-05 - Scissor Door Side Panel
