Very odd problem here - can you think of an explanation??
Discussion in 'Tech Support' started by eUphoria, 12 Aug 2007.
  1. eUphoria
    eUphoria What's a Dremel?
    9 Apr 2004
    Its a strange thing - turn PC on - nothing, no vga signal or post etc. I've tried rebuilding it, checking connections etc etc. If i leave it in this state for few minutes (PSU on, fans turning, pump running for WC) then press reset it boots absolutely fine no problems at all from then on. Strange i thought!!! Itsa little annoying, can anyone come up with an explanation for this?? :confused:
  2. DougEdey
    5 Jul 2005
    Cold start bug. Normally indicates a faulty motherboard or PSU. Try to flash the BIOS first, that can sometimes help
  3. doryakov
    doryakov What's a Dremel?
    8 Aug 2005
    disconnect the hard disk's and cd's .
  4. eUphoria
    9 Apr 2004
    Thanks Doug - will try that. Whats your money on?
    Doryakov - whats the thinking there? If i disconnect my drives how do you think it might help? I've tried it anyway - no cigar :lol:
  5. DougEdey
    5 Jul 2005
    Money would be on a faulty PSU. It may have an instable rail and switch it when it detects an issue.
