Windows VERY quick steam/games question
Discussion in 'Software' started by Matticus, 16 Jan 2009.
  1. Matticus
    Matticus ...
    23 Feb 2008
    I am about to reinstall vista because I am overdue a reinstall.
    Now steam seems to be a very portable app, I moved it from C to D without any issues, after I reinstall windows it should work perfectly fine, correct?
    If not when I reinstall steam, over the top of where it is on D: will it keep all my saves etc?
    And all of my games are on D, likelihood of those working is reasonable yes?
    Cheers in advance.
  2. badders
    badders Neuken in de Keuken
    4 Dec 2007
    You shouldn't need to even reinstall - you should just be able to create a shortcut to steam.exe
    It may ask to install the steam service when you run it for the first time. Just allow it and it should run fine.
  3. ozstrike
    ozstrike yip yip yip yip
    19 Sep 2004
    Should definitely work as long as the partition is still intact. I just resized my C drive, installed 7 on a seperate partition, and steam still worked on Windows 7 after installing the steam service. Brilliant :)
  4. Matticus
    Matticus ...
    23 Feb 2008
    Excellent cheers guys. I went ahead with the reinstall anyway. Even if I do lose my games I can always redownload and I am not bothered about save games.
    I just hope it works as you say it should.
