Storage Very slow 2.5" Sata Drive
Discussion in 'Tech Support' started by ry@n, 17 Aug 2010.
  1. ry@n
    ry@n Minimodder
    31 Aug 2005
    Im fixing a laptop for a friend, its jam packed with crap basically and it takes about 10 minutes to start, programs not much shorter.
    It hasn't been maintained at all in years so my plan was to backup all the files, reinstall Vista and put the files back.
    Theres about 40GB of data to backup, I first tried to copy this data to my External USB HDD but the copy speed was between 1MB/s and 2MB/s and kept failing due to corrupt files. I then tried in safe mode, the laptop booted and ran alot quicker but the copy speed was the same.
    I then took the HDD out of the laptop and put in an external caddy, copying the files to my PC is running at the same speed.
    Its going to take a couple more hours to finish copying but once its done is there anything I can do to speed the drive up before putting it back in the laptop? Of course, im going to do a full reformat.
    The laptop is an old Toshiba Equim model (Pentium D, 2GB Ram) running Vista and the HDD is a 2.5" Hitachi 2.5" 120GB.
  2. TheBlackSwordsMan
    TheBlackSwordsMan Far over the misty mountains cold
    16 Aug 2009
    probably and old 4200RPM IDE
    Have you tried a CHKDSK /F ?
  3. Krikkit
    21 Jan 2003
    Is it copying slowly because it's stuffed full of bad sectors? Doesn't sound healthy to me, it should be able to exceed 2MB/s without anything running (i.e. in the caddy).
    I'd get a copy of UBCD and run some drive fitness tests.
  4. TheBlackSwordsMan
    16 Aug 2009
  5. adam_bagpuss
    24 Apr 2009
    run seatools for DOS on it.
    If it fails that its time for anew drive
  6. ataraxis84
    ataraxis84 What's a Dremel?
    6 Oct 2009
    And a painstakingly long copy process
  7. adam_bagpuss
    24 Apr 2009
    use unstoppable copier for transfering data it will do it much better than windwos transfer
