VesperDeco HTPC
Discussion in 'Article Discussion' started by eddie_dane, 24 Sep 2003.
  1. Sid
    Sid Banned
    13 Mar 2002
    Ah right. My coolermaster tray is a bit different.
    I know what I need now.
    Thanks. :rolleyes:
  2. eddie_dane
    eddie_dane Used to mod pc's now I mod houses
    31 Jan 2002
  3. f U z ! o N
    f U z ! o N What's a Dremel?
    1 Feb 2004
    temps
    how are the temps in that case
    after i read ur article i was inspired to make my own case like that
    however it will look different cuz im not gonna copy peoples ideas
    i have watercooling for cpu, gpu, and chipset so im not to worried about the temps
    my other question is does the wood muffle the noise of the fans
  4. eddie_dane
    31 Jan 2002
    Sent you a reply via email but for anybody else interested:
    My design has one 120mm fan drawing air in and another one on the
    opposite side pushing air out. I haven't really checked temps in a long time
    but if I remember right when I first built it, I had idle temps of 38C and load
    temps of 47-48C. Pretty good for air cool. I don't have any overclocking going on in this case though.
    My main concern was quiet operation. It makes virtually no sound
  5. Yo-DUH_87
    Yo-DUH_87 Who you calling tiny?
    6 Mar 2002
    Sorry to resurect the thread, but where did you manage to find a pc-60 tray?
    If this has been mentioned elsewhere then :wallbash: :wallbash: :wallbash:
    Thanks :thumb:
  6. eddie_dane
    31 Jan 2002
    back when I made this, pcmods sold them individually. Since then, just finding the trays have been a bugger to find. Of course, since then, pcmods.com went for sale and I don't think they offer them any longer.
  7. Gordy
    Gordy Evil Teddy
    17 Apr 2001
    Kustom pcs had them in the uk for a while I think they sourced them direct from lian li. Maybe worth a quick email :)
  8. Yo-DUH_87
    6 Mar 2002
    Eh, thanks anyways.
    I've been thinking of doing a custom case for a while, maybe if some of these ideas will stop bouncing around inside my head and actually get put into technical drawings I'll email lian-li and see what they can do for me.
    Thanks for the help :thumb:
  9. bard
    bard Modding isn't what it used to be
    8 Mar 2003
    What are the outer dimensions of this case, Eddie? It looks huge compared to your son :worried:
    The reason why I'm asking is that I plan to start a similar HTPC project myself, also using wood and acrylic.
  10. sdat1333
    sdat1333 What's a Dremel?
    25 Mar 2005
    Hey, first of all, awesome project :)
    Im thinkin about making a case very similar to this one for my HTPC that Im building as a birthday present for me.
    Anyways I have a question. How solid is the bond between the wood and acrylic layers? Like do you have any worries about the layers coming apart ever or not? And which specific one of the loctite glues did you use? Cause I did some googleing, and theres like 50 diff types.
    Thanks
    Sean
Tags: Add Tags
