Motors Veyron loses crown
Discussion in 'General' started by padair, 14 Sep 2007.
  1. Veles
    Veles DUR HUR
    18 Nov 2005
    I thought Thrust SSC was British built?
    EDIT: I'm right, SSC in thrust SSC stands for SuperSonic Car
  2. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    I'm saying if they took out everything that wasn't needed it would hold the speed record
    less weight = faster car
  3. Colonel Sanders
    Colonel Sanders Minimodder
    25 Jun 2002
    doh - misread the last post. Plz delete this. . .
    . . . . .Post count ++
  4. wharrad
    wharrad What's a Dremel?
    26 Jul 2003
    True, although (and I'm just guessing) at 250+ MPH the drag factor is more important than weight...
  5. relix
    relix Minimodder
    14 Nov 2001
    You forgot the rumor that the designer of the gearbox got a depression trying to design the gearbox.
  6. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    ^ The gearbox in the Veyron was designed (and built!) at Ricardo, just outside of Leamington Spa. I had the fortune of looking around, seeing the gearboxes being assembled and tested. They're absolutely huge, and the double clutch system works really well. :)
  7. Amon
    Amon inch-perfect
    1 Jun 2007
    The pursuit of the production car top speed record is rather juvenile. If it continues, we'll eventually end up with cars that are impossibly short, wide, and long in an attempt to reduce drag and road friction that will look like much like this:
  8. The_Beast
    21 Apr 2007
    that looks like a turd :D :hehe: ;) :thumb: :lol:
  9. jaguarking11
    jaguarking11 Peterbilt-strong
    10 Dec 2003
    FYI: SSC = Shelby Super Car.
    Also for the guy who said the Henesy viper is not a corner carver, then you need to look at it hard. Henesy does not just up the HP it tunes the suspension as well. They were meant to be auto x cars.
