Electronics VFD loveliness - Next project
Discussion in 'Modding' started by veryevil, 23 May 2006.
  1. veryevil
    veryevil Minimodder
    14 Aug 2005
    Hi Guys, just thought i would show you what i picked up on ebay last week for a total of £12.50!!!
    2 x GU256x64-350 VFD displays
    Check out the back
    Back1
    Back2
    Im gonna be connecting one to a pic and learnign to control it Plus i might hook the other to my comp!
  2. agent420
    agent420 What's a Dremel?
    18 Apr 2006
    Good score! Looks like it's got the power circuitry onboard, probably 5v ready. Did you get data sheets as well?
  3. mingingbollock
    mingingbollock Minimodder
    15 Mar 2004
    So it was YOU :waah: :waah: :waah:
    I had my eye on , what i presume was one of these , but someone got the auction ended early grrrrrrr , you lucky lucky @@@@
    And you got 2 , hate you :waah: hate you :waah: hate you :D
    Hope you get them working mate :thumb:
  4. veryevil
    veryevil Minimodder
    14 Aug 2005
    HA ha cheers yeah got him to put a buy it now on plus he said he had two!!!!
    Also yeah they take 5v already powered them up but only the horizontal (filament???) lines come on it draws about 1.3Amps!!!
    Have ordered the connectors of rapid so should get them this week then i can connect one to pc!
  5. Turbokeu
    Turbokeu Minimodder
    30 Jul 2002
    Nice find! :thumb:
    CD :)
  6. coorz
    coorz Miffed
    25 Apr 2003
  7. veryevil
    veryevil Minimodder
    14 Aug 2005
    Thanks every one! looking forward to doing some of the things like coorz some of your diplays are magnificent!!!
    Will update when i have the cables made up
    EDIT: Coorz have you got the screen files for the displays on the linky you posted?
  8. Hazer
    Hazer In time,you too will be relixalated
    14 Apr 2003
    These are nice. Great score.
  9. veryevil
    veryevil Minimodder
    14 Aug 2005
    Hi guys, Ive made up the cables and the good news if THEY BOTH WORK!!!!!!!! (will get pics sorted out when i have something worth showing)
    However one of the screens has quite a 'nice' high pitched whine to it. Im not sure what it is (poss the high frequency voltage) but i was wondering if its a problem or if it can be fixed
  10. Turbokeu
    Turbokeu Minimodder
    30 Jul 2002
    The high pitched wine comes from the inductor of the SMPS power supply for the anode/grid voltage.
    No worry, it doesn't hurt the good working of the display.
    Locate the inductor on the component side on the PCB (near the +5VDC input) and apply some hot glue on the coils.
    With a little good luck the wine will stop.
    CD :)
  11. One~Zero
    One~Zero What's a Dremel?
    9 Sep 2004
    I've got one with the same problem. But, if I leave it running for about 10 minutes or more, the high-pitch whine "seems" to go away. And for that price, you just can't beat it! Those should be compatible, pin/function whise, with the -372, -800, and -352 (I think). So, if you can get the datasheet for one of those, you should be good to go.
  12. veryevil
    veryevil Minimodder
    14 Aug 2005
    Hey guys just a quick post befor i head of to work Got the things running and here are some quick pics i knocked up in a min or so (will post some better ones later)
  13. olly_lewis
    olly_lewis What's a Dremel?
    19 May 2006
    Good look with the hook up, if you can get some LEDs for your comp case then it'll match the VFd screens... and that would be sweet when the lights are off in the room... sweet
  14. Vito
    Vito What's a Dremel?
    19 Dec 2003
    Could you please post the link of the ebay auction? I have searched in eBay, looking for all the completed listings of vfd, and could not find yours.
    Thanks and congratulations for your adquisition!
  15. veryevil
    veryevil Minimodder
    14 Aug 2005
  16. Vito
    19 Dec 2003
    Thanks for the link.
    I wanted to find out why my searches did not success with this item. The reason is now quite clear: I have several searches for VFD, and the seller wrote "VF DISPLAY" in his auction (ITRON 256x64 DOT MATRIX VF DISPLAY).
  17. veryevil
    veryevil Minimodder
    14 Aug 2005
    Thats why i bagged them so cheap!
