Electronics VFD + printer parallel port palaver
Discussion in 'Modding' started by Goughy_Gough, 9 Mar 2002.
  1. Goughy_Gough
    Goughy_Gough What's a Dremel?
    8 Mar 2002
    after that nifty bit of alliteration, the problem :
    I want to runa VFD off my parallel port
    I also want to run a printer off it
    See the problem ?
    I am going for cheapy cheap here - hence the parallel version, but i need the display to be blue, hence the vfd.
    Hmmmmmmmmmmmmm
    Any clever ideas anyone ?
  2. Tim S
    Tim S OG
    8 Nov 2001
    Im sure you could pick up a parallel port switch box for not too much.... Ive seen them used with a parallel printer/zip drive combo... they shouldnt be too expensive to buy :)
    Also, welcome to the forums my friend! Enjoy your stay! :D
  3. linear
    linear Minimodder
    5 Oct 2001
    How about running the printer off USB via a parallel converter?
    Welcome to the boards, we could use more alliteration around here...
  4. cderalow
    cderalow bondage master!
    23 Jan 2002
    alliter...what???
    hehe welcome to the forums.... I found that getting a cheap parallel data switch was the way to go as far as thats concerned... but i use my printer a lot (on a side note, you need to turn off the LCD program before you switch to printer or printer goes nutty... learn from my experience)... but if you don't use your printer that much, you could just unplug vfd when you want to use it and leave printer unplugged the rest of the time.... thats the free solution....
  5. Goughy_Gough
    8 Mar 2002
    spliffingly good suggestions there guys - I like the idea of a USB printer, any idea where to get appropriate kit from ?
    otherwise just a whol bank of DPDTs should do the trick :p
    Hmm
    OK - next problem - serial GPOs.
    Im thinking about wiring up a PIC to my serial port to run fans, cathodes, LEDs etc as and when i can be arsed. Any ideas how hard this is onna be to implement under win2k re. software, control panel extensions etc ?
    And forgive me for being dumb, but is there any way of running an ordinary program as a service under 2k ?
    Ta muchly
    Maybe alliteration should be my trademark - look out for it in the future !:cool:
  6. linear
    linear Minimodder
    5 Oct 2001
    Disclaimer: I am not a PIC kind of guy.
    But I understand it's really straightforward. In fact, the serial displays from Matrix Orbital and elsewhere use a PIC for serial-parrallel conversion and driving GPOs.
    So why not go with a serial VFD, either homebrew using your same PIC as the GPOs, or store-bought from Matrix Orbital (or some other serial backpack arrangement that uses a PIC)?
    And then as far as services/control panel doodads/access to the ports under NT kernels you may find that using LCDriver is more satisfactory than rolling your own. Or you may very well not. ;)
