Modding VGA Angle Adapter?
Discussion in 'Modding' started by Geektechnica, 21 Mar 2005.
  1. Geektechnica
    Geektechnica Minimodder
    11 May 2004
    Does anyone know if such a thing exists?
    I'm in the first stages of designing a case, and due to the layout of the case I'd like to have the monitor cable run parallel to the backplane of the motherboard. Rather than bend the monitor cable (tight space, would have to be a sharp bend) I'd like to know if I can get a 90° adapter for my VGA port?
    Any ideas?
  2. Mattt
    Mattt Minimodder
    12 Nov 2001
    i dont know if you can and cba to search to see if you can,
    however if you cant it would not be hard to construct one.
  3. Fatboy
    Fatboy Bored
    8 Oct 2001
    If you Could source a VGA ribbon cable you would be sorted. :thumb:
  4. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    the vga monitor connectors are called Hd-15 or D-sub 15 connectors. So in the past when I made worked on my mod I looked into using right angle D-sub 15 connectors but ended up just soldeirng off the back of the board.
    Anyways yah they do exist try search for D-sub 15 right angle connectors or some such thing
  5. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Just get a 15way D-Sub plug. If you're running the cable inside your case, you shouldn't need a hood at all.
    Just be careful to sleeve your solder connections. :dremel:
