vga cooling?
Discussion in 'Hardware' started by trig, 31 Aug 2006.
  1. trig
    trig god's little mistake
    10 Aug 2006
    do you all think the thermaltake cl-w0052 tide water vga cooler is a good option for vga cooling? its about $60 usd and looks to have real good performance and reviews...of course, is it worth it to spend that kinda money on that when i plan on water cooling my cpu down the road as well? i am not real sure about cost for a good water cooling kit that will hit cpu and vga (hopefully the nb and sb too). but i wanna say i could get something for around $180 usd. wait or go ahead and grab the vga cooler? or maybe a better idea for less money?
  2. atanum141
    22 Jul 2004
    No point spending good money on average cooling like the Thermaltake unit, its allways best to get a full custom setup for both the cpu and gpu. get a nice aircooled hsf like a Zalman vf700/900 unit or a Artic silencer for your card.
    Good aircooling can easilly outperform average units like the thermaltake.
  3. [1N0V471V]
    [1N0V471V] What's a Dremel?
    27 Feb 2006
    The Thermaltake is a cheap product. Both in build quality and design. Price wise, it's OK but if I was going to water cool... it'd be the whole PC. I had a Zalman VF900CU w/ Arctic Silver 5 with a volt modded 7900GT @ 1.4v (650/1900) and load temps never went over 60c.
  4. trig
    10 Aug 2006
    seems like good advice...less than half the money for about 65-75% of the cooling...i just cant seem to find anywhere where it says specifiaclly that the coolers (700 or 900) work on the x1800 series...
  5. atanum141
    22 Jul 2004
    They will work on the x1800 and x1900 series, they have the correct holes and i have seen people have then on such cards.
  6. Fibbles
    Fibbles What's a Dremel?
    22 Apr 2004
    I used a Zalman VF900 on my x1800XL and now on my 512mb 7900GT. It fits.
    The info should be on Zalman's website.
  7. trig
    10 Aug 2006
    cool...thx fellas...
