Planning VGA extension
Discussion in 'Modding' started by Editor22, 8 Dec 2009.
  1. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Hopefully someone can help me out with a problem we have at work :)
    We have a projector that we are mounting to the ceiling but need to make a vga extension for it so as to allow users to plug in there laptops, its going to be about 10meters long but we can get the cable fine only problem we have is I've never had to wire in a VGA plug :sigh:
    Anyone know the following;
    1) How hard it is?
    2) Is there any special tools needed?
    3) Alternatives?
    4) Online guides?
    Thanks to anyone who can help :clap:
  2. CrapBag
    CrapBag Multimodder
    17 Jul 2008
  3. Editor22
    3 Jan 2009
    thanks for you reply crapbag.. that was my initial idea but it turns out the we need to put a plate similar to this on the wall by the presenters table.
    Dont really want to go buying one until I know if I'll be able to wire it up : /
  4. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Looking at that plate couldn't you just unscrew the connector and then screw in the one connected to the extension cable. Not sure if there would be a clearance issue at the back, it all depends where the plate would be fitted too.
  5. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    You need something like this
    Front
    Rear
    You could use a standard 10 metre cable with this and would be a piece of piss to fit :D
  6. SkiDave
    SkiDave Minimodder
    16 Mar 2008
    Don't you have to be careful with long vga cables as the signal degrades over the longer distance?
  7. Stickeh
    Stickeh Help me , Help you.
    20 Jul 2003
    Yeah, but 10m will be fine, i used to run one in my car :)
  8. Editor22
    3 Jan 2009
    Awesome, thanks alot guys looks like its gonna be cheaper than the £500 the projector company quoted :worried:
