Electronics VGA specification
Discussion in 'Modding' started by Moriquendi, 27 Mar 2007.
  1. Moriquendi
    Moriquendi Bit Tech Biker
    3 Nov 2005
    I am trying to find out more about the VGA standard, as in the one we use to connect monitors to graphics cards rather than the internal adapter specification. Its easy to find out about the old graphics card specification but not what goes down the wire as it were.
    What im after is the different voltages for the colour signals and the timings but if anyone knows a good complete reference site that would be best.
    Moriquendi
  2. Kipman725
    Kipman725 When did I get a custom title!?!
    1 Nov 2004
  3. Moriquendi
    3 Nov 2005
    Ive already got all those but i need more detail. For example, for component video the signal voltages are different in PAL zones from NTSC zones but VGA monitors are inter-changable so which standard do they use? or is it something different again?. And how does the timing differ for different resoloutions?
    Moriquendi
  4. smoguzbenjamin
    smoguzbenjamin "That guy"
    6 Sep 2004
    VGA -> PC monitors
    NTSC -> US television
    PAL -> EU television
    VGA has absolutely nothing to do with PAL or NTSC. It's a seperate, worldwide standard, which is why VGA monitors are interchangeable.
  5. Splynncryth
    Splynncryth 0x665E3FF6,0x46CC,...
    31 Dec 2002
  6. Moriquendi
    3 Nov 2005
    @ Splynncryth; Yes, thank you, that is exactly what I was looking for.
    Moriquendi
