News VIA launches world's smallest quad-core PC
Discussion in 'Article Discussion' started by Gareth Halfacree, 1 Nov 2012.
  1. Gareth Halfacree
    4 Dec 2007
  2. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    I'm always curious to know how these sort of systems compare to older existing stsyems.
    For example: My parents have an Athlon X2 PC at home. Would this new tiny system offer lower, similar or better performance? (Assuming both had the same SSD) The clock kspeed is much lower, but then it's a newer design and it has twice as many cores? Given that they only do office stuff and web browsing, I'm assuming this system would be enough.
  3. John_T
    John_T Minimodder
    3 Aug 2009
    I wonder the same thing, as I reckon systems like this would probably cover 90%+ of the time people actually spend on their PC's. I always feel a little guilty with my big power PC whirring away while I spend hours just surfing the web / sending email / doing very basic office work...
  4. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    shame it does not have dual nic, would be a awesome pfsense box.
  5. cornelius1729
    cornelius1729 What's a Dremel?
    28 Feb 2011
    Sounds like an ace HTPC box.
  6. asura
    asura jack of all trades
    22 Apr 2009
    The question ultimately will be one of availability... If you're in the UK and want a Pico-ITX board from VIA that isn't 5 years old, then you have to get it from far afield. From the USA on ebay seems to be the easiest way. And pay circa forty pounds for the postage, then VAT, import duty and a handling charge to get it released to you once it hits the UK adding (I guess, number pulled out of thin air) about another forty to sixty pounds... with postage, VAT, duty and handling fees coming to approximately fifty percent of the value of the product, it becomes madness.
  7. PingCrosby
    PingCrosby What's a Dremel?
    16 Jan 2010
    If I was Inch High Private Eye I'd buy one
  8. schmidtbag
    schmidtbag What's a Dremel?
    30 Jul 2010
    It will likely be more power efficient, quieter, and produce less heat, but I highly doubt it'll be much faster, if at all. First of all, VIA's processors have never been known to be fast. But secondly, depending on what you do, a dual core is all you really need. Even single cores can be enough for the average user. Tablets are good proof of this - they're popular because they appeal to the average person who wants to just sit back and browse the internet, so single core ARM processors (which generally perform worse clock-per-clock compared to x86 processors) often work just fine.
    While I think parallel processing is becoming more of a reality in the future, a cheap quad core for a web browsing and email computer can potentially be a worse decision. If you only have maybe 3 tabs open at a time (or a browser that uses 1 process for all tabs), you'd likely get better performance out of a 3GHz dual core than a 1.5GHz quad core of the same architecture.
  9. Ploo
    Ploo What's a Dremel?
    1 Oct 2009
    It's really difficult to judge if we don't know the price.
  10. Jimbob
    Jimbob Minimodder
    2 Jul 2009
    It doesnt look any smaller than my old Zotax Zbox, great litle PC that has spent the last couple of yeas woring behind my bedrom TV as a HTPC. Wit a SSD it's quick and totally silent. (-:
  11. Kacela
    Kacela What's a Dremel?
    19 Apr 2011
    Price in the US starts @$320 : http://bit.ly/VPelKQ
