CPU VIA Pico-ITX - any questions you want to ask VIA?
Discussion in 'Hardware' started by Guest-16, 17 Aug 2010.
  1. Guest-16
    Guest-16 Guest
    I'm picking up a VIA Pico-ITX kit in a few days - is there any burning questions you'd like to ask VIA about their Pico kit while I'm there?
  2. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    All I can think of quickly is do they have a pico-ITX board suitable to run a NAS? E.g. some SATA ports for at least 4 hard drives (hopefully more).
    I really want to be able to build my own NAS as small as proprietory ones.
    Whilst the C7 would be sufficient for a NAS (just - depending on add on modules), they never seem to come with more than a single IDE or SATA interface. Is this a pico-ITX limitation or are we simply not there yet?
  3. confusis
    confusis Kiwi-modder
    5 Jan 2006
    Why no PCIex16?
    J/K XD
    Is it possible to integrate some form of onboard PSU (with an external 12v adapter or something)
    and can there be at least 2 hardwired USB ports on the main board? and maybe a single audio jack+maybe a mic jack?
    I'm probably asking too much of the form factor but a few ideas I have need these onboard rather than on an add-on board that increases size!
    SATA?
  4. Singularity
    Singularity ******* Operator from Hell
    2 Mar 2008
    This, mainly. A pico board with 4 sata ports would be amazing.
  5. Guest-16
    Guest-16 Guest
    OK Pico w/ lots of SATA.
    The Pico kit already has a case and DC-DC power unit built in. The Pico board itself has audio and USB too afaik.
  6. klutch4891
    klutch4891 What's a Dremel?
    4 Feb 2008
    +1 to more SATA. I don't think having loads is necessary, but 2 would be nice. One for a HDD and one for a ODD so you could use it as a tiny HTPC.
    As for the audio and USB - the P820 has USB, but the only audio seems to be through HDMI or using a 9 pin header (from what I can see at least).
  7. beatter
    beatter I Like Pie
    31 Jul 2010
    Any plans for USB 3.0 soon?
