VIA Pico-ITX Goes Low Profile, Integrates Power Supply
Discussion in 'Industry News' started by Guest-16, 28 Jun 2008.
  1. Guest-16
    Guest-16 Guest
  2. DougEdey
    5 Jul 2005
  3. W-fault
    W-fault Otherwise known as widefault
    16 Mar 2008
    The DVI-D is on the pin header behind the VGA and COM port, so it needs a cable.
    10 cm x 7.2 cm, but how much bigger is it with the two boards attached?
  4. tominated
    tominated What's a Dremel?
    28 May 2008
    finally. it was a PITA getting all those pin header cables staying in the pins. i might have to look into this...
  5. BentAnat
    BentAnat Software Dev
    26 Jun 2008
    My question is: how good are these things at decoding HD video? I really want to build my dad a home entertainment system based on something tiny and quiet.
  6. Guest-16
    Guest-16 Guest
    I might be able to tell you soon, but I expect HD video - poor.
  7. BentAnat
    26 Jun 2008
    Would be interesting, Bindi.
    I'm thinking of building something around that (or ATOM). Emphasis on read-only (no need to encode anything), headless (preferably - controlling it should ideally happen through one of those aftermarket LCD's that casemodders use all the time. :p)
  8. W-fault
    16 Mar 2008
    Portwell PEB-2736, 105mm x 140mm. More expensive, not as small, but should be a better performer and about as good for power usage.
