News VIA ups AMD chipset FSB to 1GHz
Discussion in 'Article Discussion' started by GreatOldOne, 7 May 2004.
  1. GreatOldOne
    GreatOldOne Wannabe Martian
    29 Jan 2002
    800Mhz FSB's are so last year you know... this from elReg:
    VIA this week launched its latest chipset for AMD processors, upgrading its current K8T800 product to support a 1GHz HyperTransport-based frontside bus speed.
    AMD chips already support the 1GHz FSB, but still work with the older 800MHz bus. VIA is essentially catching up with the CPUs.
    The new part, the K8T800 Pro, also boosts the speed of the proprietary bus that links the chipsets North and South bridge chips from 533MHz to 1066MHz.
    More here
  2. Carbon
    Carbon Banned
    8 Jan 2003
    hmmm, sounds good :D !! i wonder what nvidia will do with the nforce chipset to compensate?
  3. [cibyr]
    [cibyr] Sometimes posts here
    30 Nov 2003
    Woot! Yet more bandwidth for those luuvely hypertransport systems :D
  4. Sparrowhawk
    Sparrowhawk Wetsander
    14 Feb 2004
    More bandwidth = better! Always! :naughty: :D
  5. ric449
    ric449 What's a Dremel?
    7 Mar 2004
    I don't get this, 1 GHz FSB? They are only at 400MHz FSB up to now though! Or am I thinking of the wrong bus here?
  6. penski
    penski BodMod
    29 Aug 2002
    Think: what else runs at a speed dependant on the FSB?
    *n
  7. fump
    fump What's a Dremel?
    14 Aug 2003
    the 32 bit athlons ran at 400MHz fsb max, the amd 64, opterons and the fx's all have the faster hypertransport system which removes the link between the cpu and nortbridge by placing it inside the cpu, insted that bus is used for memory and southbridge interactions.
  8. ric449
    7 Mar 2004
    Ok, thanks. I should really read up on the AMD 64 architecture. :duh:
  9. ArmyAnt
    ArmyAnt What's a Dremel?
    6 May 2004
    Yeah, 64 bit reg links to itself at a max of 1600mhz and supports up to 256 terabytes (yes, 1000gb in a tb) of ram.
  10. Carbon
    Carbon Banned
    8 Jan 2003
    256Tb of ram :naughty:
    Windows will need that before to long :hehe:
  11. ric449
    7 Mar 2004
  12. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    What I am struggling to understand is why companies release new products that have negligible use to anyone, especially when they know full well that it just adds cost :eyebrow:
  13. Novakog
    Novakog What's a Dremel?
    17 Mar 2004
    Just FYI, I have heard many (at least 10) examples of how biased Tom's Hardware is.
    Also, some motherboards with the NF3 250GB actually allow you to up the HT link on it to 1000 Mhz - not sure if it was overclocking it or simply to allow for processors that can support it, but I remember seeing that option in BIOS.
Tags: Add Tags
