Windows Vibrating Mouse
Discussion in 'Software' started by acidfire, 22 Nov 2004.
  1. acidfire
    acidfire What's a Dremel?
    11 May 2004
    Alright, I seem to be having an issue with my mouse. It vibrates. Or twitches. Whatever. Either way, its been a pain to edit in photoshop, 3dsmax, etc. Any suggestions as to why i've been having the problem? I think its software based since it does it even when I unplug my mouse. help :wallbash:
  2. aaronrkelly
    aaronrkelly What's a Dremel?
    1 Jan 2004
    Your mouse oscilation bearing is going out - either lube it and see if the problem goes away or replace the bearing. They are not that expensive.
    My mouse does this occasionaly as well but Im using a cheapy optical mouse and its just losing track on a shiny surface. I would say drivers but I dont think the problem would persist when the mouse is removed. My mothers old computer does this too and I could not fix it. I reinstalled the OS, tried drivers and everything. I finally just plugged in a USB mouse and went on with it.
