Apple Video converting for iPad
Discussion in 'Software' started by alleyne, 30 Jan 2012.
  1. alleyne
    alleyne What's a Dremel?
    11 Sep 2007
    Hey Guys
    I would like a little help. i have been given an ipad 2, well strategically stolen my mums :clap:. I am having trouble finding a free program that will convert my movies/series into the required format.
    I have tried google, but everything thats "free" is not or if it is it has some catch :wallbash:. i wont be doing any dvd ripping or anything like that, just want to put my existing files onto my ipad.
    what are people using?
    thanks
    (windows 7 64 bit, i5, 4 gig ram, 5870 1 gig)
  2. saspro
    saspro IT monkey
    23 Apr 2009
    Handbrake is all you need
  3. wyx087
    15 Aug 2007
    i've been using kvip, but it is a batch file processor, doesn't have ANY configurable option. released in iPhone 1/3G era, so output video quality is pretty low. but at least file size is small and allows you to store a lot of videos.
  4. alleyne
    11 Sep 2007
    Thanks bro :rock:, i thought it was more of a ripping program. i am busy trying it out. anyways to make the converting quicker. mpeg4 rather than h.264 (will i be losing quality?)
  5. alleyne
    11 Sep 2007
    thanks for the input. not to worried about file size, but wouldn't want to sacrifice quality.
  6. Cruelinios
    Cruelinios EvE Addict
    21 Jan 2002
    Dont bother converting, get flexplayer. Drag n drop a film onto the iPad and watch it, any format.
  7. adam_bagpuss
    24 Apr 2009
    h.264 is better than mpeg4 as you get the same quality for around half the size. However its more CPU intensive but should be fine i think.
    there are Iphone presets on handbrake maybe a an ipaqd one i forget best thing is to play around with it a bit.
    For Ipad you will need to use MP4 as the container ipad supports h.264 and various audio codecs but not sure which.
  8. Cruelinios
    21 Jan 2002
  9. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    Freemake is good for converting to h.264 aac m4v. It is a LOT faster than handbrake. There is a point in converting if we're talking about hd. No reason to have 1080p high bitrate file that takes up half the devices storage when you can drop the quality with it still looking quite good and using a fraction of the space.
  10. Cruelinios
    21 Jan 2002
    Very good point, I didn't think of space :)
  11. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    +1 to freemake, awesome little program.
  12. improprietary
    improprietary FT03 is a bitch to watercool
    13 May 2011
    i remember something about a program that will change the "packaging" from .avi to .mp4 and most of the time the only thing that needed recoding was the audio. I can't remember anything about where to get sadly :(
  13. IvanIvanovich
    31 Aug 2008
    mkvtomp4... but the video codec already has to be h.264 or it can't do a container change. It does .avi even though there is no mention. Not sure if that was what you were thinking of?
    This is the quickest way by far to get an mkv or avi to ipad compliant mp4, but it won't make it (much) smaller if it is a huge HD file. There will be a slight filesize reduction going from dts/ac3 to aac, but not huge.
  14. YEHBABY
    YEHBABY RIP Tel
    22 May 2010
    Use MAKEMKV to rip your DVD's. (I know you said you don't need to rip, but someone else might find this step useful).
    Then use FREEMAKE or HANDBRAKE to encode into MP4 format for playback on the iPAD. :thumb:
    FREEMAKE is probably the easiest to use for a novice.
  15. Bladesingerz
    Bladesingerz Minimodder
    30 Nov 2011
    +1
  16. IamJudd
    IamJudd Modder
    30 Oct 2011
    Adding a comment do I can come back to this... Cheers!
  17. Guest-16
    Guest-16 Guest
    Wrong.
    Freemake
    +1 to everyone else \o/
  18. alleyne
    11 Sep 2007
    Thanks a million bro, this is perfect. didnt know apps did this. Thanks to everyone for their help..:clap:
  19. Penfold101
    Penfold101 What's a Dremel?
    1 Jun 2010
    Youtube Downloader is another one - I use it to both download stuff from youtube (randomly enough...:D) and it can also convert to mp4 and various other formats. It's a very basic program so compared to the likes of handbrake etc I wouldn't expect much, but it's small and easy to use.
    I shall look at the other ones with interest...
  20. wyx087
    15 Aug 2007
    am i missing anything with Freemake?
    tried it out last night, at same resolution as kvip, and same frame rate, it's twice size of kvip with same quality. problem it seems is that it is constant bit-rate.
    anyone know how to make it variable bit-rate? a Xvid encoded TV show at 178MB is encoded to be 180MB using x264 with worse quality due to lower iphone1 resolution, something has to be wrong here.
    interface is well designed though. and like the trim/combine feature.
