Cooling Video of how heatsink compound spreads...
Discussion in 'Tech Support' started by neil_b, 9 Jan 2011.
  1. neil_b
    neil_b Member
    20 Jun 2009
    This - www.youtube.com/watch?v=EyXLu1Ms-q4 - Youtube is very interesting, it shows how heatsink compound spreads underneath at the interface between the top of the CPU die and the underneath of the fan/waterblock plate........
    DELETE this duplicate post please! (couldn't see how to delete it myself!)
  2. bulldogjeff
    2 Mar 2010
    Thats interesting. I tend to go for the blob in the middle or spreading. looks like I'll be a blobber from now on.
  3. kenco_uk
    28 Nov 2003
    I've been a spreader, I rub it into the heatsink with a finger in a sandwich bag and then spread a thin layer on the cpu/ihs. I think I'll use the pea or cross method in the future!
  4. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    It depends what processor I'm using. Example would be that when I rebuilt my old P4 550 system recently for a friend I used something between the rice grain and pea method. But when I am using a Core 2 I use the line method in the same direction that the chips are oriented under the heat-spreader.
  5. ultimatedesk
    ultimatedesk New Member
    18 Nov 2010
    Thanks for posting that vid, very informative
  6. adam_bagpuss
    24 Apr 2009
    ive always done the rice grain method so nice to see that it works best
  7. j.col
    j.col Member
    23 Dec 2010
    just seen a same thread in the hardware forum by same OP
    http://forums.bit-tech.net/showthread.php?t=201152
    Originally Posted by _Fanatic View Post
    I reseated my q6600 a few times using spread, line and cross. Never saw a single temp difference but hey ho. Interesting vid all the same, haven't seen it before.
  8. Throbbi
    Throbbi New Member
    10 Sep 2009
    Thats very informative :)
    Personal preference has always been spreading. The laminated card inserts from Corsair RAM has always worked well for me lol.
  9. IAmATeaf
    IAmATeaf Member
    9 Jun 2006
    So the pre-spreading method leaves air gaps, damn this is the method that I've always used :(
  10. neil_b
    neil_b Member
    20 Jun 2009
    I suppose when you think about it, squashing a blob means that you start with no/little air between the cooler plate and the die surface, then you're simply forcing out that blob (that had no/little air to start with), and air can't "appear" out of nowhere if it wasn't there to start with.
    Conversely, if you spread out the compound first, it's probably virtually impossible to get it totally flat, and there will therefore be a certain amount of undulation and variation on the surface after you've spread it, although not necessarily apparent when just looking at it from 12-24 inches away. It's likely that when you put the cooler plate on to that (slightly) undulating layer of compound you're first trapping air in those undulations, then compressing them out as you apply pressure - which is exactly what the video shows.
    The Arctic Cooling web site recommends a line of compound, which sort of follows the above logic, but probably gives greater/better coverage than a simple blob etc? in my humble opinion, every little helps when trying to get a stable and cool PC.
  11. Mattmc91
    Mattmc91 Well-Known Member
    18 Oct 2009
    grain of rice sized dob of TIM in the middle, either AC MX-2/3 or Noctuas own for me.
  12. kylesaisgone
    kylesaisgone New Member
    23 Oct 2010
    That's some useful info right there! Thanks
  13. Votick
    Votick My CPU's hot but my core runs cold.
    21 May 2009
    normaly i spread the cpu paste, will blob it form now on :)
    thanks for the link
