Graphics video output issue
Discussion in 'Tech Support' started by adam_bagpuss, 12 May 2010.
  1. adam_bagpuss
    24 Apr 2009
    heyo,
    got a bit of a wierd issue with outputting 2 displays at once.
    1 is over VGA the other is over S-video (which is converted to component).
    i can seem to set up multiple displays in windows or get it to recognise the S-video at all.
    it does display the post screen etc on boot on both displays but when windows starts to load it turns off the S-video.
    im using a 8400 series geforce card with latest drivers.
    anyone any ideas on how to get it to output to S-video only or VGA+S-video would be better
  2. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    nvidia control panel it should say something about setting up multiple displays.. in there dualview for TV+Monitor- a svid cable would work better than taking it down to composite
  3. adam_bagpuss
    24 Apr 2009
    nvida control panel doesnt recognise the S-video output at all.
    tried to setup multiple displays but nothing happens after i try to activate a second monitor
  4. thehippoz
    19 Dec 2008
    yeah it should work.. maybe try a svid cable out to the tv instead of converting it to composite- I use svid on the 260 and it detects and displays
  5. adam_bagpuss
    24 Apr 2009
    well the TV its going to doesnt have S-video which is why it was coverted to component.
    i guess i could try a different connection maybe ill take another card and try that too. think ive got a spare one lying around somewhere
