Windows Video Split software? fast, easy to use?
Discussion in 'Software' started by wyx087, 29 Dec 2010.
  1. wyx087
    15 Aug 2007
    is there any fast and easy to use video splitting software?
    i just got a Sony blu-ray player with USB port, but just found out that Sony only supports FAT32 file format. so to play 1080p films, i'll most likely need to split a 8GB MKV file into 4GB slices.
    is there any video file split software that don't require to encode the whole video again? and pretty easy to use (eg. set split point or set desired size, then press Go)
    thanks :thumb:
  2. jrs77
    jrs77 Modder
    17 Feb 2006
    You might try this one -> http://www.avs4you.com/AVS-Video-ReMaker.aspx
    It isn't freeware tho and I don't know what limitations there is for the "trial". The standard-version works however like intended.
    EDIT: Oh and yes I know people don't like AVS usually, but what do I care for if it does what I want it to do :p
    wyx087 likes this.
  3. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    wyx087 likes this.
  4. tripwired
    tripwired Deploying Surprise in 3... 2...1...
    12 Feb 2009
    DVDFab might be worth a shot, I've been using it for a couple years for creating ISO files of my DVDs as backups, it has the option to 'split' movie files into smaller chunks. I've not used that aspect of the program before as I've had no need to, although it looks pretty straightforward.
    wyx087 likes this.
  5. jrs77
    jrs77 Modder
    17 Feb 2006
  6. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    is there a reason you can't connect the computer to the screen itself and play direct? i know sometimes i overlook the obvious, but it may be a lot easier than 1, splitting up a movie file, 2, copying it to some external usb media, 3, playing on another device - maybe. assuming it doesen't have a fit from the file format, bit rate, frames per second etc... it is a sony device after all.
    wyx087 likes this.
  7. bubsterboo
    bubsterboo What's a Dremel?
    24 Jan 2006
    This is the proper way to split a MKV file without re-encoding it.
    If you're dealing with MP4s you can use mp4box (a command line utility) or grab the frontend for it. Yamb
    And TSMuxer for .m2ts and .ts
    EDIT: Does it accept MKVs? if not you can remux the mkv into a .m2ts without re-encoding anything. This will definitely work in a blu-ray player.
    wyx087 likes this.
  8. wyx087
    15 Aug 2007
    forgot about this thread. thanks for the bump, rep+ all round :)
    i found a software, very similar to mkvtoolnix, except it's designed specifically for Sony players (started for PS3) it's MKV2vob. you just start it, set a few settings like DTS is supported by the TV or not, subtitle to be included or not. then just queue files to it. :D very easy to use and can queue lots files for overnight conversion. all of its output have been successfully played on the player.
