Cooling Views on water cooling
Discussion in 'Hardware' started by H4z4RD0uS, 1 Nov 2003.
  1. H4z4RD0uS
    H4z4RD0uS What's a Dremel?
    19 Oct 2003
    I do now know wut i want! water cooling is way better but risky, thats why i didnt get it, since im new to this PC stuff. maybe in like 1-3 years i will purchase a water cooled rig
  2. Risky
    Risky Modder
    10 Sep 2001
    Well now we know your view, I think.
  3. H4z4RD0uS
    19 Oct 2003
    no
    im just saying, wut do you guys think bout it?
  4. [KT] Mike
    [KT] Mike What's a Dremel?
    5 Oct 2003
    .LOL risky, does seem like a kinda pointless post.
    What do I think? Each to their own as they say, no one's pressuring you.
  5. olv
    olv he's so bright
    23 Sep 2002
    Unless CPU manufacturers can increase chip efficiency and reduce the ever growing heat output of CPU's in the future, then watercooling is pretty much going to be a matter of need, rather then desire.
  6. [KT] Mike
    5 Oct 2003
    What about Phase-Change and Thermo Electric
  7. olv
    olv he's so bright
    23 Sep 2002
    I meant as a replacement for aircooling which is the mainstream cooling for the majority of computers in the world.
  8. [KT] Mike
    5 Oct 2003
    Im not so sure, air coolers are getting better and better and I think they'll be around a while longer yet. CPU heat output may also decrease as manufacturing processes get better.
    But, water cooling is already becoming more mainstream, as we've seen with the NEC computer in Bindi's presentation. As it becomes cheaper (which it will) more peole will turn to it but the fact still remains that the n00bies in the high street stores as soon as they hear compter + water they back away so its gonna take a pretty good marketing team to get it mainstream, successfully anyways.
  9. ConKbot of Doom
    ConKbot of Doom Minimodder
    2 Jul 2003
    I was tired of the noise in my computer, so I wanted to put one in, but I only have one rig, so I would have to take it to lan parties, I didn't feel like having to drain it and re-fill every time I have to move it, then after I moved it I would be wondering if any tubes cam loose and will come off when the pump comes on.
    For a stay in the same spot, rig it is fine, for a semi-mobile rig, I just didn't feel comfortable.
  10. Murdoc
    Murdoc Gas Mask..ZOMG
    25 Jul 2003
    i wat to go watercooler, prob with a £200-£250 budjet, i see it as if im going WC then i may as well do it right first time, save money in the long run. but my mobo has no mounting holes, i know i can get a hold-down for the maze4 im looking at but im not sure if i should upgrade my mobo and ram first.....ah dilemas (if any1 is interested i have generic PC2700 and GA-7VR mobo xp2400+ @xp3400)
    Murdoc
  11. [KT] Mike
    5 Oct 2003
    With that sort of budget you should be looking at the Aqua Computer stuff. Its expensive but it looks like the best kit.
  12. H4z4RD0uS
    19 Oct 2003
    some manufacturer should make a 100% safe water cooling kit, and it's impossible to leak unless done intentionally. that'll boost their sales and hapiness.
    wut I Dream of is an acylric full tower case (those things are sexy) or a mid tower aclyric UV reactive with some water cooling :D
  13. [KT] Mike
    5 Oct 2003
    How can you be exactly sure a watercooling part is never going to leak? You can be 99.999% sure that a fault wont occur but its impossible to guarantee something like that as the designers cant think of all the circumstances that could take place.
  14. Murdoc
    25 Jul 2003
    if they make everything sealed (tubes selaed to block etc) then they could say if it leaks we replace it and wots its damaged.
  15. Tim S
    Tim S OG
    8 Nov 2001
    but what happens when you have a non standard motherboard with the CPU socket in a diff place? you either don't have room to accomodate the excess tubing, or you don't have enough tubing to reach :)
    edit: plug and cool is fairly fool proof if you are careful.
  16. olv
    olv he's so bright
    23 Sep 2002
    but thats the same for pretty much any watercooling or even phase change. its easy if your careful.
  17. [KT] Mike
    5 Oct 2003
    What is this plug and cool thing? I've seen it on A-C's products and wondered how it worked.
  18. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    I'm willing to take the risk for the bonus of a near silent system (darn these hard drives).
    It's all down to being confident that you have installed it all correctly.
  19. Risky
    Risky Modder
    10 Sep 2001
    It means using"Push-fit" fiitings. THese are fitting normally used for pneumatic systems and make a completely sealed connection when the tube is pushed fully into the fitting. They are commonly used in most european watercooling setups and imo are a damm good idea.
    For someone new to watercooling it does pretty much eliminate the risk of a leak from the hose-fitting provided they cut the hose straight and push the tube in all the way.
    There are some nice animations and diagrams of how they work on the Legris site but its down at the moment.
  20. [KT] Mike
    5 Oct 2003
    OK, thanks for clearing that up, makes sense now :hehe:
