Hardware ViewSonic VP2365wb Review
Discussion in 'Article Discussion' started by arcticstoat, 18 Jan 2011.
  1. arcticstoat
    arcticstoat Minimodder
    19 May 2004
  2. mi1ez
    mi1ez Minimodder
    11 Jun 2009
    If it wasn't for an iminant move abroad, this would be mine by March! Great looking monitor!
  3. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    sweet monitor, I do need a monitor I can swivel into portait, and view my photographs on with accurate colour repoduction and at resonable price this look like the monitor for me :D
  4. dangerman1337
    dangerman1337 Minimodder
    2 Sep 2010
    Is looks like a good Eyefinity/Surrond for good value. (though you will probably need an adapter for Eyefinity).
  5. woof82
    woof82 What's a Dremel?
    18 Jul 2005
    Ha, I bought the NEC MultiSync EA231WMi yesterday, I should have waited for this review! Looks amazing, maybe I'll just have to go dual monitor :)
  6. Guest-23315
    Guest-23315 Guest
    I've always had a soft spot for Viewsonics..
    I've still got a VX912, VX924 and a VX922 sitting happily at home.
    Having said that, I'm still very happy with my 4 year old Dell which does the trick.
  7. Paradigm Shifter
    10 May 2006
    You don't have to pay "nearly £100 more" for DisplayPort. The Dell U2311H has DisplayPort, is IPS, and can be had for ~ £260.
  8. Jipa
    5 Feb 2004
    Lovely. A great choice for those looking for a cheap screen. Sure, one can have a TN-crap for much less, but most of those don't even have a proper stand, or any adjustments, so even if you don't value the proper panel, you're still getting your moneys' worth in ergonomics.
  9. neonplanet40
    neonplanet40 What's a Dremel?
    3 Mar 2003
    The Dell u2311 is better. This monitor came out last summer . . . . .
  10. Aracos
    Aracos What's a Dremel?
    11 Feb 2009
    I still can't have my dream monitor, 24"or 23" 1920x1200, e-IPS panel with displayport and DVI and a zero screwed pixel warranty! Yeah 1920x1080 is taking over and mostly took over now but I'm a gamer that goes back to old games, I'm currently playing morrowind now and are forced to run it at a non native resolution which looks horrible because my monitor is 1680x1050, if I had a 1920x1200 monitor I could have it at 1600x1200 and it would look perfect. I'm basically limited to the HP HZ24W or whatever, maybe I could get one with somewhere that has a pixel guarentee =\
  11. t5kcannon
    t5kcannon Minimodder
    7 Jan 2011
    I got one of these monitors, and am very happy with it. Has Bit Tech even reviewed the Dell U2311? It's a quality IPS monitor, which I got on special offer from Dell for £222. I use it for gaming and watching movies.
  12. praxis22
    praxis22 Geek
    5 Feb 2010
  13. sub routine
    sub routine Archie Gemel
    27 Sep 2007
    looking for a new monitor right now and this is very tempting. Just wanting something slightly bigger without the mental price increase.
  14. coliea
    coliea What's a Dremel?
    18 Jan 2011
    I wanted the exact same specification and have just purchased a HP LP2475W for £357 delivered. OK, so HP don't to my knowledge offer a zero dead pixel gaurantee, but as an ICT manager I buy hundreds of cheaper TN panels each year and in my experience dead or stuck pixels are a rarity these days.
    The HP LP2475W is a 1920x1200 H-IPS panel (the same panel in an Eizo will cost you a grand), has Display Port, HDMI, DVI and a host of other inputs, and once properly calibrated is fantastic (it's much too bright out of the box).
    IMO at £360 it can't be beaten. Check out the reviews on Trusted Reviews, PRAD, TFT Central, etc.... and of course bit-tech.
  15. 63jax
    63jax What's a Dremel?
    18 Jan 2011
    perfect, i love ips and pva panels. it was about time they were becoming affordable, and i hope all the TN **** will disappear from the market. i am also on the move to buy one good panel to replace my Samsung 226bw, a 22inch with full-hd res is enough for me, don't like big panels, small screens + hi res equal crisper image. keep them coming...
  16. Mentai
    Mentai What's a Dremel?
    11 Nov 2007
    I currently have the Viewsonic VX2260WM - 22" Full HD monitor. Would the image quality increase be noticeable enough to justify an upgrade in your opinion?
    Edit: For reference, I use my PC for gaming and bluray watching.
  17. sb1991
    sb1991 What's a Dremel?
    31 May 2010
    Could Bit-Tech maybe invest in some monitor calibration equipment? Qualitative descriptions of the lagom tests are a poor substitute for hard numbers, and leave this website looking amateurish compared to others (such as AnandTech and TFT Central). Most of the reviews here involve rigorous testing and are generally excellent, but with monitors we're left with wooly descriptions like 'a touch colder' and 'slightly deeper blacks'. You note that 'It's difficult to say subjectively which is the more accurate'... why not just buy a colorimeter and say it objectively?
  18. Guinness
    Guinness What's a Dremel?
    29 Jul 2010
    I bought the NEC early last year following the Bittech review. This Viewsonic was actually available then for about £260 (£40 less than I paid for the NEC). There were no reviews around at the time I chose to pay the extra
  19. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    question still remains should i go with this or the 26 Larger monitor for the same price??
    hmmm
  20. t5kcannon
    7 Jan 2011
    Well said. Bit Tech seem to do good reviews on the majority of PC hardware, but offer really poor coverage of monitors. When they do a review, it is decidedly second rate stuff, missing rigours analysis and stuffed with subjective comments. Hard to gauge anything much from such reviews.
    Bit Tech give plenty of PSU, case, fan, etc, etc group tests, which is great, but when was the last time anyone can remember a monitor group test? I just don't get why they choose to do this. A good monitor can make a huge difference to a PC user's enjoyment. High time for Bit Tech to take monitors seriously, and extend their good reviewing standards to cover monitors.
Tags: Add Tags
