Hardware ViewSonic VX2739WM Monitor Review
Discussion in 'Article Discussion' started by Lizard, 13 May 2010.
  1. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
  2. vampalan
    vampalan What's a Dremel?
    18 Jun 2003
    Hmm.. Lacking in resolution, but has the right connectors, maybe missing S-Video. Size seems good. I think this would suit triple screen eyefintiy setup or maybe other 3 screen computer games. GT5 on 3 screens anyone?
    Price wise I thinks this one is relatively cheaper than other 27 inch screens, but a touch too expensive for a 1080p screen.. had it been same pixle height as the dell 27 inch, I would have ordered some.
  3. amdavies
    amdavies What's a Dremel?
    11 Mar 2009
    This shouldn't really even be mentioned in the same breath as the Dell because of the vast difference in panels, It'd be like comparing a Mini with Ferrari because they both have 4 wheels. A much better comparison would be with the Hanns-G 28" 1080p monitor that's been floating around for a couple of years IIRC.
    The only reason I can think for buying a 27" 1080p over a 23" or 24" is if you want to sit further away from it as the difference in screen size allows for a bigger distance between screen and viewer(s) whilst maintaining the same perceived resolution.
  4. memeroot
    memeroot aged and experianced
    31 Oct 2009
    Resolution is everything
  5. Claave
    Claave You Rebel scum
    29 Nov 2008
    As the screen lacks a DisplyPort input, you'd have to buy an expensive active DP-DVI/HDMI adapter to make a three-screen Eyefinity setup. Just thought I'd point that out before anyone rushes off to buy three before checking :)
  6. Stewb
    Stewb What's a Dremel?
    16 Dec 2009
    Is the u2711 not 16:9?
  7. vampalan
    18 Jun 2003
    Good point. Arent they just simple dongles like HDMI to DVI?
    I believe it is 16:10.
  8. merple
    merple What's a Dremel?
    18 Dec 2007
    Yup, it says its 16:9 2560x1440 in the bittech review that is linked in this review.
  9. Primoz
    Primoz What's a Dremel?
    22 Dec 2007
    2560 x 1440 is 16:9. 2560 x 1600 is 16:10. Which is it then?
  10. Dave_M
    Dave_M What's a Dremel?
    29 Jul 2007
    It's 16:9. The 27" is a cut down version of the 30" dell. I believe they are the same width. Just cut some of the top off the 30" until you end up with a 16:9, which happens to make it a 27" screen.
  11. Claave
    29 Nov 2008
    How thick do you think 160 rows of pixels are?! The 27in is a different panel, not just a 30in with bits cut off - after all, what would be the point of that? You just waste LCD substrate...
  12. Farfalho
    Farfalho Minimodder
    27 Nov 2009
    I have forked out 220€ for my Asus VK246H and I'm very happy with it. The preset settings avaliable really make a difference while using it in various environments. Never noticed that backlight bleeding and other things. It's 1920x1080, 16:9 and I don't seem why you say the 1920x1200 should be present on 24" and above monitors, I can't see why
  13. bogie170
    bogie170 What's a Dremel?
    11 Aug 2008
    Viewsonic used to be a good company putting out quality products.
    All I see from them now is mid-range crap.
  14. vampalan
    18 Jun 2003
    Been looking at the Asus VW266H, its a tad smaller than this Viewsonic in the review, but it has more resolution and more connections, its about the same price too.
  15. knuck
    knuck Hate your face
    25 Jan 2002
    Completely off topic but I just saw in another article that you qualified the Samsung 2233RZ as being a poor monitor and I must ask; Were you high ?
    I know I am being an ass tonight but I don't understand how perfect fluidity cannot make a screen at least very, very good. It's aimed at gamers and is the only panel on the market (or was anyway because there are other 120hz monitors now) that can actually be used to play FPS games
  16. V3ctor
    V3ctor Tech addict...
    10 Dec 2008
    I have a VX922 (2ms) and that is one hell of a monitor... It kicks my Samsung T260 ass. With beautiful colors and small response time, it's like night to day...
    I can't believe that Viewsonic, a company that was very good in their products is turning in a mediocre company...
  17. wyx087
    15 Aug 2007
    need higher resolution. please give those manufacturers a kick when you next see them (except Dell) why do we get stuck with full HD resolution when we sit much closer to the monitor?
    when i buy a 27 inch monitor, i expect to be using a higher resolution than my over 1 year old 24 inch. now lower.
  18. hexx
    hexx What's a Dremel?
    9 Dec 2008
    TN panels - that's never gonna be good, ips is way to go
  19. CowBlazed
    CowBlazed What's a Dremel?
    9 Dec 2005
    The 2233rz has simmilar issues as this, fast response for gaming but colour and everything else is not good. Its also over priced for a 22" which offers nothing but 120hz.
    One good thing doesn't make it very good, makes it mediocre at best.
  20. knuck
    25 Jan 2002
    which is THE only thing needed for gaming. Therefore it's great. I win
Tags: Add Tags
