So I've had everything installed and working for a while now, I didn't bother installing the WiFi/Bluetooth module at the time because Powerline seemed to work fine. Now though, I realise that using the WiFi would probably give me a slightly better signal. Looking at the computer though, the hole that the antenna goes through on the I/O shield is covered by plastic. Does anyone know how to remove it? http://cdn.overclock.net/7/74/74f67e74_20140627_213057.jpeg Will I need to take the whole PC apart to get to the I/O shield?
Yeah now I feel a bit thick. I was being too careful before, just needed to push it hard with the tip of a pen. Thank you
Hah, I felt exactly the same - they were really quite solidly connected and required quite a lot of force to push them out.
