Scratch Build – In Progress Vintage style PC
Discussion in 'Project Logs' started by vortchun, 5 Aug 2009.
  1. vortchun
    vortchun What's a Dremel?
    6 Dec 2008
    So this is my latest work in progress. It will be pc that looks like mix of a tube radio and military radio station. First thing the sketch.
    there will be two separate decks in upper mATX mainboard and control panel, in lower PSU HDD and DVD. All wires will go through the posts.
    For material i use wood, but later will paint it to look like metal.
    Cutting an ordinary PVC pipe for posts.
  2. sentek
    sentek What's a Dremel?
    5 Jul 2009
    nice work so far :thumb:
    subscribed:)
  3. Pashtet
    Pashtet MonstaMods
    18 Feb 2009
    great idea
    sub'd too
  4. Hazza
    Hazza What's a Dremel?
    25 Nov 2003
    Brilliant, I love stuff like this. Looking forward to more progress!! :)
  5. Krog_Mod
    Krog_Mod What's a Dremel?
    23 Sep 2003
    It's almost a shame to paint that, I like how it looks already. I personally would stain and varnish that, but that's just my preference. I can't wait to see how the paint job turns out though, so good luck when you get to that part.
    Nice idea with the PVC pipe posts by the way. What did you use to cut the holes for them? I'd like borrow that idea since I'm planning on building a wooden PC.
    Also, just because I'm curious; What do you plan on using for the handles?
  6. tarator
    tarator What's a Dremel?
    7 Mar 2008
  7. DonT-FeaR
    DonT-FeaR I know what a fk'n Dremel is ok.:D
    23 Jul 2008
    ok thats a cool design
  8. docodine
    docodine killed a guy once
    10 Feb 2007
    Cool so far, but you would've gotten extra props and rep++ from me if you bent the wood to make the frame. ;)
  9. null_x86
    null_x86 Thread Closer
    18 Jan 2009
    looks nice so far, just wondering are you using a Socket 479(also known by socket M or Socket P, Mobile Intel C2D) mobo?
  10. vortchun
    6 Dec 2008
    adjustable circule cutter. looks like this
    tarator спасибо! мне он тоже больше всего нравиться
    null_x86 its socket 478 and i use it just for modeling
  11. Pashtet
    Pashtet MonstaMods
    18 Feb 2009
    а я думал, тут русской кодировки нету )))
  12. vortchun
    6 Dec 2008
    here are my other works
    notatoad likes this.
  13. Krog_Mod
    23 Sep 2003
    Thank you very much, I believe I'm going to try to find one at the hardware store next time I get a chance. :dremel:
    Also, I like that steam-punk mouse ^^. and please tell me that lightbulb flash drive lights up somehow.
  14. vortchun
    6 Dec 2008
    heres a picture for you. is this answers you question?
    continue with project. cut holes in lower section. the round ones are for fan (there will be psu without case). used car body filler to make case look like it is made from one piece
    and a little bit of art :D
  15. DonT-FeaR
    23 Jul 2008
    ok that lightbulb idea is really cool!
  16. maRiio
    maRiio What's a Dremel?
    27 Jul 2009
    Haha I've got to agree with DonT-FeaR, it's very nice :D
  17. vortchun
    6 Dec 2008
    thanks guys!
    cut and painted mesh (i got my from trucks used air filter, this way it dont cost a thing). starting to make control panel for upper section. later the panel will be painted in dark brown.
    dont worry this is only the primer.
    after first layer of paint, made a pause and enjoyed a cherry tobacco with dark cherry beer
    and the second layer
  18. DonT-FeaR
    23 Jul 2008
    starting to take even more shape! looking wicked
  19. voigts
    voigts What's a Dremel?
    26 Apr 2006
    this is really slick. Very original.
  20. vortchun
    6 Dec 2008
    the lower and upper panel with voltmeters.
    making the fanbus with LM317T. for chip cooling i use old graphic card radiator.
    and how control panel will look. now i have to make the new one, because the engraving didn't turn out so well.
