Scratch Build – In Progress Vintage Terminal AIO
Discussion in 'Project Logs' started by Božo Kaurić, 29 Apr 2020.
  1. Božo Kaurić
    Božo Kaurić What's a Dremel?
    25 Apr 2020
    Hi all!
    I got around some older parts that my friend did not need any more, so I took the MoBo, CPU,RAM,GPU,PSU and HDD... also took out a 17" Full HD screen from a broken laptop (also the speakers from it)... and I got thinking... what to do with it... I knew I wanted to do an integrated thing, with vertical screen... After some time designing it in my head, I sat down and did it in 3D.
    That is what you can see here. I also cleaned and tested all components, installed OS and got it all working, so no I only gotta find some time and get all the parts that I need to build this.
    Freakin isolation is not helping me, cause almost all stores are closed over here... but, bit by bit and it will be soon done.
    You will be wondering whats with the cables up front... well, I decided to make video and audio signals selectable, so you can plug in the integrated display and speakers or use external ones. Connecting internal display and speakers this way just seemed cool to me, nothing else.
    Here are the renderings, and as soon as I start building it, I`ll post my progress over here.
    censored_Prometheus_ likes this.
  2. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    I love it !
    Honestly...... if i could render like that i prolly wouldn't need to mod !
  3. Božo Kaurić
    25 Apr 2020
    Its a great feeling when you imagine something, design it, render it and then make it ;) The full circle ;)
    idpcmods likes this.
  4. kim
    kim hardware addict
    10 Jan 2016
    :clap:I agree DÈF¥âÑt¸.·´¯`¤ this will be pretty cool, mod it mate, make the full circle :rock:
    Božo Kaurić likes this.
  5. idpcmods
    idpcmods Minimodder
    30 Jun 2015
    Can agree with that.. greatest feeling.
  6. Cheapskate
    13 May 2007
    The 3d modeling just makes you want to build more, Def.
  7. Božo Kaurić
    25 Apr 2020
    Its handy when you have an idea in your head, to see how it would actually look like, and then to tweak all the details and see possible problems before you start building
  8. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
    Very nice plan. Love the selectable internal video/audio option.
  9. Božo Kaurić
    25 Apr 2020
    I love the look of modular synths, so I had to have some external cables. Good thing you can find anything on Aliexpress, so red cables are on the way ;)
  10. Sam__
    Sam__ Minimodder
    22 Sep 2012
    That looks very nice! Can't wait to see it.
  11. ciaognep
    ciaognep Minimodder
    10 May 2020
    very interesting project:clap:
