Modding Vinyl Dye(ing)?
Discussion in 'Modding' started by NOMIS, 6 Apr 2005.
  1. NOMIS
    NOMIS What's a Dremel?
    7 Jun 2004
    Hey
    I am going to vinyl dye the front plastic part of my case black. The plastic panel has 2 blue strips down the sides of it, does this mean I will have to dye them white first and then do it black? Because I've heard that doing it black on dark colours gives it a funny tint sort of?
    What you guys think?
  2. DeathAwaitsU
    DeathAwaitsU I'm Back :D
    27 Feb 2004
    You could always see what it looks like without painting it white, it may give a cool look that you'll like ;) .
    Death
  3. NOMIS
    7 Jun 2004
    Hehe nah I'd rather have it black. The blue bits are just painted on, can I just sand it off or will this ruin the plastic and make it look funny when I dye it?
  4. mobius9
    mobius9 Minimodder
    4 May 2004
    if the plastic is smooth, it might make it look like a different texture. You could always try some of that chemical paint remover stuff.
  5. Liquid Steele
    Liquid Steele What's a Dremel?
    11 Apr 2005
    Be careful with strippers and solvents many of them will just dislove the plastic in a computer case.
  6. tk421
    tk421 Idiot.
    15 Jan 2002
    black over blue shouldnt be a problem ...
    you should only need to prime with white dye when going to a lighter color, i.e. from blue to yellow or red ...
