Modding Vinyl Dye On Acrylic Bezel
Discussion in 'Modding' started by RoshDogg, 15 Apr 2003.
  1. RoshDogg
    RoshDogg What's a Dremel?
    28 Dec 2002
    Hey all, question about dying. My case's acrylic bezel is clear, and the dye I own is plasti-kote vinyl coloring, which I've heard is not true dye. I've already used it on my drive bay covers and it worked great, I just wanted to check if anyone knew/can confirm that it will work on the the clear acrylic. Thanks!
    RoshDogg
  2. linear
    linear Minimodder
    5 Oct 2001
    Confirmed. It will work. I like to sand the surface first with a very fine grit, I think it makes the color look slightly deeper. Even if you don't, adhesion to acrylic was excellent in my tests (it didn't scratch off).
    And of course, paint the back side. It will look really really great.
    And welcome to the boards.
  3. eddie_dane
    eddie_dane Used to mod pc's now I mod houses
    31 Jan 2002
  4. RoshDogg
    28 Dec 2002
    Thanks for the information, I wish I could get mine to look as good as yours, eddie! Well I'm off to finish my mod, thanks all!
  5. eddie_dane
    31 Jan 2002
    np... not difficult really, just do light layers and keep it in a safe place while drying so it doesn't get contaminated with dust/bugs... will come out great.
