Modding Vinyl Dye VS Spray Paint
Discussion in 'Modding' started by NoObY-DoObY, 1 May 2003.
  1. NoObY-DoObY
    NoObY-DoObY Hanging on by a thread...
    29 Apr 2003
    is vinyl better because i never used it but i have spray paint but i used different kinds but it like "chips" off so can u help me? please be honest or u "calm" down on "me" because i dont know
    so is there a "permanent" or the best one that people here often use?
  2. Shadowspawn
    Shadowspawn Another hated American.
    1 Jul 2002
    Vinyl dye is a dye, more than a paint. On plastic or vinyl surfaces, its the best for a permanent color. Its not for metal.
    If your paint is flaking and its a metal surface, are preparing the surface correctly? washing, sanding, primering?
  3. NoObY-DoObY
    29 Apr 2003
    ok...??? so u have to wash it, sand it, etc?
  4. Shadowspawn
    1 Jul 2002
    What exactly are you painting?
  5. NoObY-DoObY
    29 Apr 2003
    i already did keyboard and mice but it stinks
  6. linear
    linear Minimodder
    5 Oct 2001
  7. Shadowspawn
    1 Jul 2002
    Figured linear would come to my rescue with some linkage...
  8. CommanderMcBride
    CommanderMcBride What's a Dremel?
    29 Apr 2003
    You want a really good finish, airbrushing is the only way to go.
  9. coolmiester
    coolmiester Coolermaster Legend
    31 Dec 2002
    ....good word:thumb:
    you got to make sure your surface is clean dry and totally free from oil...silicon etc.... use a good primer otherwise the paint has nothing to attach itself to...key! thats why its chipping off easily!
    Some of the dyes are great for keyboards and drive fronts but you got to make sure you put it on even and its also a good idea to give more than one coat to build the colour up :cooldude:
  10. NoObY-DoObY
    29 Apr 2003
    o i get it so u use vinyl for plastic and airbrush for metal?
