Modding Vinyl Dye
Discussion in 'Modding' started by George, 7 Jun 2002.
  1. George
    George Bah
    14 May 2002
    Does anyone know where can i get this stuff ?
    thanks,
    .icecube
  2. Will
    Will Beware the judderman...
    16 Jun 2001
    Halfords
  3. George
    George Bah
    14 May 2002
    thanks again will.
    .icecube
  4. Lazy
    Lazy Meow?
    13 Nov 2001
    halfords call it somthing different i think but it still has the word vinyl in. It might be called vinyl spray or paint.
  5. Digital Fodder
    Digital Fodder What's a Dremel?
    30 Aug 2001
    It is called vinyl die in halfords and comes in three colors. £9.99 for 500ml, also make sure you don't do too many thin layers as it makes the drive bay grainly to touch and look. No more than 5 layers.
  6. Coolrunnin
    Coolrunnin What's a Dremel?
    20 May 2002
    The stuff I got from Halfords was called 'Flexible Vinyl Paint' (got the can in front of me now) It would be worth looking for that name as well :)
  7. Digital Fodder
    30 Aug 2001
    flexible stuff is the one...sorry forgot about that bit. you will be mighty chuffed once done...just not to many layers! also becarefull when the can starts to run out because they spitt and youll get nasty shinny blobs. Happy spraying!
  8. Stew
    Stew Disgruntled Postal Worker
    6 Mar 2002
    yep its flexible vinyl paint, the name rubs real easily off the can :)
    10 squid it is, but its good stuff :dude:
  9. Coolrunnin
    20 May 2002
    Yep - real good stuff indeed - I've done the entire front panel of my Addtronics 8600 (****ing massive!) and I got a flawless finish despite me being less than good at spraying. In fact this paint's so good that you'll see all the imperfections in the plastic you're painting that you didn't think were there when it was beige!!!:D
    If you get an uneven finish as well - don't worry! When I was doing some of the more intricate bits of the drive bay area I got an uneven shiny finish from overspray - Oh no I thought.... WRONG! I just sprayed another even coat over the panel again and voila! one perfectly even finish with no hint of previous **** up! exxxxerlent :D :dude:
  10. George
    George Bah
    14 May 2002
    thanks guys.
    perfect :)
    .icecube
  11. Lazy
    Lazy Meow?
    13 Nov 2001
    if you look at Linears website then he gives a good guide on how to use the stuff.
  12. scoob8000
    scoob8000 Wheres my plasma cutter?
    17 Feb 2002
  13. Lazy
    Lazy Meow?
    13 Nov 2001
  14. George
    George Bah
    14 May 2002
    Hey
    i got some today from halfords.
    i tested it on my smoothwall, the front of the case and the CDROM.
    perfecto!
    then i done it on my propper drives, and they have turned out really bad!! >_<
    im going to have to get a new pair of drives >_<
    .icecube
  15. Will
    16 Jun 2001
    Doh! My mate (who will go unmentioned, but is a member here ;)) did the same, messed up painting his drives.......
    You can always sand them down and respray the bezels though (I did this once whilst experimenting with paints on my old CD drive, the paint actually started to bubble the surface of the plastic.............a bit of sanding, rubbing, humbrol model filler and polishing and all was fine again :)) or if you're really cheeky you can email the company who made your drives, saying that you bought it from a computer fair and when you got it home the bezel was cracked and the try was loose......well it worked with Liteon ;) so I keep my warranty but still get nice black faceplates........
  16. George
    George Bah
    14 May 2002
    right.
    after 4 hrs 30 mins.
    ive scraped all the paint off two cd drives and re sprayed them.
    perfecto'
    .icecube
  17. ug_the_caveman
    ug_the_caveman What's a Dremel?
    31 Mar 2002
    lol, you have way toooooo much time on your hands!
    Ug :)
