Modding vinyl wrap cut to size
Discussion in 'Modding' started by bluc, 25 Aug 2012.
  1. bluc
    bluc What's a Dremel?
    4 Apr 2012
    Hey all wondering if anyone knows of someone that sells automotive vinyl wrap cut to size? I have a fair amount of aluminium square tube I want to wrap and would like to buy the wrap cut to size to make the process easier. Thanks in advance cheers,:dremel:
  2. Kylevdm
    Kylevdm The Mod Zoo Podcast Host
    4 Oct 2007
    Check out any of your local sign making shops they should be able to do it for you.
  3. bluc
    4 Apr 2012
    Ok will do thanks :D
