-Vio1's Lian Li V1000- *(Project Silver)*
Discussion in 'Project Logs' started by Vio1, 30 Jul 2004.
  1. Mace
    Mace Ohh, it stings.
    9 Dec 2003
    I can't even see it in the larger pictures... it's not really something to go and blow money on... But yeah... if you have supplies try fixing it.. just don't waste money on it!
  2. Exomoto
    Exomoto What's a Dremel?
    21 Sep 2004
    Same here, cant see it in the bigger pictures, although i'm sure the idea of an imperfection must be annoying :p.
    Maybe cover it up? you could put bolts through the door holding the window and make sure you put one over the scratch, or put a border around the window that goes over it.
    Or cut a sorta dotted line ( --- --- --- ---) going around the window that goes through the gash? I've never seen anyone do that before.
    Other than that I can only suggest filling it partially, then filling the rest with paint and sanding the whole thing a little to smooth it out. Wont be perfect but at least there wont be a hole to catch the light.
  3. Vio1
    Vio1 What's a Dremel?
    29 Mar 2004
    thnx for the ideas. As to cutting out a whole pattern.. it would be so very difficult to get it right (especially with my newbie dremel skills).
    I think im gonna sand it down. What grit do you think i should start off? 600? 800?
    Should I sand it down to a mirror finish?
  4. Mosha
    Mosha What's a Dremel?
    31 Jul 2004
    Not to mirror finish that would ruin it imo
  5. Providence
    Providence What's a Dremel?
    23 Jan 2004
    Don't sand down the panel, you definitely wont be able to get a good look out of it.
  6. Vio1
    29 Mar 2004
    Then what are my options? I have to do something to cover up some of the nicks I made (note to self... next time cut from the back of the case door!)
    I dont want to paint it... I cant think of anything to cover it with...
    What would be wrong with a mirror finish?
  7. Mosha
    31 Jul 2004
    Is it really that noticeable?
    If you were to do a mirror finish, some other parts would also have to have mirror finishes, because it might have a weird contrast
  8. Vio1
    29 Mar 2004
    There isnt just one mark... and they are noticable
  9. Mosha
    31 Jul 2004
    Mirror finish would be the way then!
  10. Providence
    23 Jan 2004
    Or get a case skin, those are tight
  11. Vio1
    29 Mar 2004
    Where do you get case skins? Nice ones...
  12. Mosha
    31 Jul 2004
    Case skin would mess it up because the interior fits with the current outerior
  13. Vio1
    29 Mar 2004
    you EXterior.... haha... outerior isnt a word.
  14. NzC
    NzC What's a Dremel?
    7 Sep 2003
    Is there any way you can mod the door so that the outside is the inside and the inside is out? Or get some nice molding? Possibly paint a border (would have to be throughout the case then and would have to be just perfect).
    Good Luck on the fix and nice project.
  15. blknoel
    blknoel What's a Dremel?
    14 Jun 2004
    is that a lot of fans? :eyebrow:
  16. Vio1
    29 Mar 2004
    there are 6 fans in the case... i dont think its a lot.
  17. Vio1
    29 Mar 2004
    Update!
    Filed down all the edges... and inserted the plexiglass... its a bit hard to see but the plexi glass is installed in the pictures below.
    Its not glued in yet, because i still need to sand the door (cause of some scratches.)
  18. Exomoto
    21 Sep 2004
    looking, looking, looking harder, looking harder....
    ....soooo, where are these painfully obvious scratches?
  19. Vio1
    29 Mar 2004
    They dont come out well in pictures... just trust me, when you see it in person they are noticable.
  20. malcs
    malcs oops! i put a hole in the ***** :(
    24 May 2003
    just get an anodising company to recoat it
