-Vio1's Lian Li V1000- *(Project Silver)*
Discussion in 'Project Logs' started by Vio1, 30 Jul 2004.
  1. ModKid
    ModKid What's a Dremel?
    5 Jul 2002
    Yeps, scared me the first time too, just don't have the unit next to you, cuz you'll think the machine will explode :p It's all perfectly fine, it just makes alot of noise that's all.
  2. Vio1
    Vio1 What's a Dremel?
    29 Mar 2004
    a pic of how it looks from the back ... if anyone wants more pics let me know.
  3. Vio1
    29 Mar 2004
    Here is my latest addition to my case: An ATI x800XT Plantinum Edition (genuine, not softmoded):
    Here are some pics:
    now to benchies and overclocking!!! I'll be back in a little while with the results.
  4. TekMonkey
    TekMonkey I enjoy cheese.
    6 Dec 2002
    :jawdrop: :eeek: where did you get a hold of that?
  5. Vio1
    29 Mar 2004
    ebay
  6. devenfore
    devenfore LANCandy
    8 Jul 2003
    Hmmm. Same place I buy all those kidneys.
  7. <A88>
    <A88> Trust the Computer
    10 Jan 2004
    Looks like someone wont ever need to upgrade again...just hit the big red OC button when half-life 3 comes out and pwn valve ;)
    <A88>
  8. Firehed
    15 Feb 2004
    My guess is by then we'll be having 4-8 core procs with 64+ GPU pipelines :hehe:
    Looks nice though. you should do something about that ram cooling plate on the back - it drove me nuts on a friend's build (x800XT non-PE but same cooler). Seems so large and out-of-place. Maybe try and at the least give it a brushed look to match the case a bit.
  9. jezmck
    jezmck Minimodder
    25 Sep 2003
    same place I sell mine.
  10. Vio1
    29 Mar 2004
    Hey guys I need some help. Im sanding down my side door and i have a prob. When i touch the sanded door it leaves a fingerprint that wont come off (even with a light sanding). Why is that? Any ideas on how I can remove it? How can I protect the surface from staining like that?
  11. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    You might use paint thinner, or any kind of stuff like that. Adhesives remover and terpentine might work as well.
    Good luck on the finger prints mate, I really love the project!
  12. Dean_j2001
    Dean_j2001 What's a Dremel?
    1 Apr 2003
    LOLOLOL
  13. Firehed
    15 Feb 2004
    Try rubbing alcohol.
  14. Vio1
    29 Mar 2004
    Finally! Some updates:
    Been working on my case door:
  15. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    Looks like you sanded the anodising off. Good job sir :hip: :D Now you've got to do the rest of the case ;)
  16. Franklin
    Franklin What's a Dremel?
    24 Oct 2004
    Wow that looks good :rock:
    Removing the anodising causes the problem of the fingerprints. You can solve the problem of those nasty fingerprints by a company that also chromes materials. I don't know the english terms for it, but I had some simular problems and asked a metalworker what to do with this problem. In Dutch it is called "blank chromateren.
  17. Vio1
    29 Mar 2004
    to shine it up i used a palmsander. Whats odd is that i tried 600 grit... and it look like crap. Tried 1000 grit, and still it looked like crap... Then i dapped a little bit of car wax on the case door and tried the 600 grit and it came out beautifully shiny once the sandpaper wore out. It doesnt make a difference if i use 600 or 1000 grit, same finish results. I tried the same thing with a super fine scrub paste and it didnt come close to this. I tried spraying water and it didnt become shiney at all... for some reason this wax really buffs out the metal. Plus finger prints DONT stay on... so it both shiny and clean!
    Every time i look at the door and I shake my head in disbelief on how good and shiny it looks... It honestly looks like a crome job..
    And here i thought I was coming close to finishing this case up... oh how wrong I was.
    Im gonna install the mesh and plexiglass tomorrow... so new pics will be up then.
  18. Leeum
    16 Feb 2004
    Is the VapoChill LS unit in anodised aluminium? If it is you'll have to get that done aswell as the rest of the case :D
  19. Vio1
    29 Mar 2004
    thats the plan
  20. Razor_cut
    Razor_cut What's a Dremel?
    12 Mar 2004
    Thats gona be a shiny metal monster!
    The overal case is nice, the LCD and the original idea with the grill over the motherboard. But huw hard would it be to change the edges betweene the LS chassi and the V1000?
    Im currently stuffing my LS inside the V2000 and that leaves the LS case outside, but try to figure out a idea of fil the edges..
    Great modd!
    And its silver :eeek:
