-Vio1's Lian Li V1000- *(Project Silver)*
Discussion in 'Project Logs' started by Vio1, 30 Jul 2004.
  1. Vio1
    Vio1 What's a Dremel?
    29 Mar 2004
    I have a question about:
    Its 12v, and i was thinking of replacing the fan on the arctic cooler for this one... however this one doesnt blow all that hard.. The issue i have is that when I start up the computer with this blower plugged, its starts to blow really well for the first second, and then mellows out... is it maybe not getting enough juice? I have it plugged into the black and yellow connections in the molex plug.
    Another question regarding my lcd:
    How do I setup my dual monitors so that the sceensaver runs on the mini lcd and not on my main crt monitor, yet have my crt monitor the primary display (cause if i put the llcd as the primary display all windows open up on it... and its so tiny.. i cant read it.)
  2. -=Clew=-
    -=Clew=- What's a Dremel?
    24 Mar 2002
    Well it's rated for 1.34A, so it should blow your head of, almost :p
    Could be some kind of temperature-thingy. They often begin with 12v to let it spin up, and then they adjust the rpm to the temperature.
    Look for a termistor!
  3. Vio1
    29 Mar 2004
    Would that inside the blower be the thermister?
  4. spinDr
    spinDr What's a Dremel?
    13 Nov 2003
    that is quite a nice lcd screen you have there.
    What are its dimensions?
  5. -=Clew=-
    24 Mar 2002
    Cant really see on that pic, but isnt that thing there a component with a blue body och 2 legs? Maybe its something else..
  6. Vio1
    29 Mar 2004
    bump
  7. Vio1
    29 Mar 2004
    i snipped one wire connecting to the blue thing and nothing different happened.
    Im wondering... could my problem something else? The blower had a third white wire coming from the motor.... what was that for?
  8. Vio1
    29 Mar 2004
    anyone??
  9. Rocket733
    Rocket733 Austerity - It's the only way
    27 Dec 2003
    Just taking a wild guess but could the white wire be a ground or something? Maybe the temp. monitor wire or something? Do you have another power adaptor to test the fan with?
  10. Vio1
    29 Mar 2004
    no, nothing else to test it with... any idea what that blue thing is?
  11. Rocket733
    27 Dec 2003
    Nope, don't think it's a temp. monitor because I looked up the PDF for that fan and it doesn't indicate what the blue thing is.
  12. Vio1
    29 Mar 2004
    Attached my new moded cpu fan:
  13. -=Clew=-
    24 Mar 2002
    Well, that certainly is a termistor on the pic.
    Don't care what the pdf says, that couldn't be anything else.
    If you connect the two legs om he termistor, there will be no resistance, and therefore the fan blow spin at 12v all the way :p
  14. Vio1
    29 Mar 2004
    what do you mean "connect the two legs"? I cut off the blue thing with its legs and the fan still doesnt blow any better.
  15. Vio1
    29 Mar 2004
    Anyone? I need to figure if I can use this blower now, cause otherwise Im gonna go down to a surplus store and find me another... Anyone?
    If that blue thing is a thermister, and I cut it off altogether... and it still didnt improve the airflow of the blower (which pushes very little air) then is there any hope for this blower? anything I can do to speed it up?
  16. ArtificialHero
    ArtificialHero We were just punking him sir!
    25 May 2004
  17. The_Resetter
    The_Resetter I LIKE CAKE!
    6 Oct 2003
    just put the 2 legs together :wallbash:
  18. Vio1
    29 Mar 2004
    I cut the two wires together... are you telling me to connect them together now? wont that short curcuit it or something?
  19. Vio1
    29 Mar 2004
    Okay, i tired connecting them... GEEEEzuS! holy crap! It worked, and nearly blew my head off! The only prob is its way too loud.
    So i connected it to the 5v line instead, and its working at a decent level... is it alright to use the 5v line instead?
  20. Vio1
    29 Mar 2004
    Next week Im going to spend it all on this mod (cause Im off of work, and school starts the week after, and my parents are away on vacation.... So next week is MOD WEEK.... starting Tuesday afternoon (cause i have something important I need to do at school).
    What I want to do next week:
    1) Install my lcd
    2) Hook up my new psu (if it comes by then) and have all the cables in placve and hidden
    3) finish modding my videocard cooling
    4)maybe install a window (we shall see)
    5) Im sure something else will need to be done... just cant think of it right now.
