Windows Virtual CDRW
Discussion in 'Software' started by Dr. Coin, 2 Feb 2022.
  1. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
    I am looking for a utility or software that will install a virtual optical drive that can be detect by other CD burning software and write the 3rd party image to disk. Anyone know of such a thing?
    OS: Windows 10
  2. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    Are you wanting to convert between disc images essentially?
  3. wolfticket
    19 Apr 2008
    If you want to create a disc image from files you will need a bit of software. This is a simple neat utility that doesn't require an install: https://www.videohelp.com/software/Folder2Iso
    Then for other tasks right click an ISO in Windows 10 you get "Mount" and "Burn disc image".
    I think that should cover you(?)
  4. Dr. Coin
    13 Sep 2013
    Bit more clarification.
    The issue is I'm using a laptop with no optical drive. I am looking to create a virtual CDRW drive that 3rd party software can see and use. The software does not support creating disk image directly it has very limited features.
  5. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    I don't know of any tools that will emulate a CDRW in that way - there used to be loads of ISO mount tools, but I can't ever recall anything that mimics an actual CDRW.
    For the hassle involved, couldn't you just pick up a USB CD burner - they only cost about £20?
  6. Gareth Halfacree
    4 Dec 2007
    It's been a while since I did any kind of CD-related stuff on a Windows box, but last I remember Virtual CD allowed you to create a virtual burner which would write to images. Instructions are here. It's payware, but there's a 30-day trial which should sort you out.
  7. sandys
    sandys Multimodder
    26 Mar 2006
    Same not done it for a long time but think Macrium reflect might do this also on the personal free tier.
    I though Windows did this natively, or is that only when you have a CDRW you can build a disc before burn?
  8. Gareth Halfacree
    4 Dec 2007
    I think, but don't take it as gospel 'cos I'm not a Windows user these days, that you can build an ISO image for saving or burning from a directory of files, but you can't fool a piece of software that's looking for a physical burner into creating an ISO image without Virtual CD or similar.
  9. ModSquid
    ModSquid Multimodder
    16 Apr 2011
    Not sure if I'm misunderstanding the requirement, but would Imgburn or DaemonTools help? Both are free when I last checked some time ago. The versions I have can create iso images from folders/files without the need for a physical drive to be present..
  10. noizdaemon666
    15 Jun 2010
    Virtual CD would be a good shout as last I checked it could create a virtual disc drive as Mr Gareth said.
  11. Dr. Coin
    13 Sep 2013
    Virtual CD looks promising. Thank you
    DaemonTools! how could I have forgotten about DemonTools? Oh right, while free they started packing it with spamware so I stop using and and forgot about it. Not sure if that is still the case. Looks like it might also be a option but not the free version.
    Thank you to everyone for there replies. I have some testing to do.
  12. ModSquid
    16 Apr 2011
    Do let us know how you get on, bud - the interweb is full of unfinished threads without solutions...!
