Virtual PC 2007 - Internet Connection
Discussion in 'Tech Support' started by mnorth, 1 Oct 2007.
  1. mnorth
    mnorth What's a Dremel?
    10 Jan 2006
    I don’t even know if this is possible but…
    I have a XP Pro computer running on a domain logged in with admin right’s, full internet access etc. In Virtual PC 2007 I’m running XP Pro as a guest operating system. I want the guest operating system to have full access to internet but without the virtual pc connecting to the domain.
    I.E. I want the guest operating system to access the internet using the host’s connection. Using some sort of pass-through.
    Any help much appreciated.
  2. Poisonous
    Poisonous Incestuious
    18 Apr 2007
    Is there a reason you need full access? Just set a user policy on the guest account.
  3. mnorth
    10 Jan 2006
    I'm going to be running plenty of programs on the VM which will need to connect to the internet to download different things (files/modules/information etc). Also I don’t want to log on to the VM with an account as I’m trying to avoid having the VM connected to the domain at all. Hopefully the VM can just use the connection of the host machine (which is logged on to the domain) to get its connection.
    Sorry if this isn’t very clear. I’m rubbish at explaining things.
  4. IAmATeaf
    IAmATeaf Minimodder
    9 Jun 2006
    Depends all on how the other PC access the internet and if internet access requires domain authentication.
    Have a look at the TCPIP properties and see what the default gateway is set too, then put this in as the default gateway for the VM and see if you can connect.
  5. Delphium
    Delphium Eyefinity enabled
    18 Mar 2007
    You could also change the network setting in the virtual pc properties so that the connection is bridgged. If you require to auth on the domain to get internet, if the host machine can connect, you could also used share internet connection in the host machine, and point the virtual pc internet gateway to the host pc.
